I've done a few.......thousand.
On this specific application, OEM projectors......they can be a bit tricky for a first timer. If you've never opened a headlight, opening a set of $1200 (MSRP) lights can be a bit scary!
The halos and C bars, there really is only one brand out there, made by Morimoto......but, they no longer stock them - they updated a few things......I bought them out of the remaining 100mm rings and fitted C bars (as we do quite a bit of those here at RetroShop). After the lights are open, the rest is relatively self explanatory, nothing crazy.....
We typically pair it with the lower Diode Dynamics switchback boards, solder it all to the OEM parking/turn light circuits, makes for a very easy install back onto the truck.....as there is absolutely no wiring required by the customer then.
Hit me up if you are interested in a quote -
[email protected] - thx!
