Bed Lights
Bob0233
Purchased a 2017 Ram 1500 and it did not come with bed lights. I can see the spots where they should be mounted but have not looked for the wires. Are these pre-wired?
GraniteCrystal
Albany, NY
There is a mopar kit for adding the led bed lights. 2017 part number is 82214870AB. I believe that this kit requires a sales code to be flashed into the truck for it to work. Good luck!
Robocop_9
West Virginia
My 2017 came with the light installed. It wouldn't work. When I crawled under it I found the harness and plug but no where to plug it in. SMH
Taking it in Tuesday to get it fixed
R/T_Fire
Pleasant Grove
You can also use a LED rope light stuck to the underside of the bedrail and just wire it to the Cargo light switch and you will have much better lighting in the bed.
Something like this
https://www.youtube.com/watch?v=HYJYdOC3hQY
Personally I wouldn't recommend tying it into the trailer wiring like that but that's just me, It's more work but tapping into the cargo light power but worth it to me to tap in to a pre-existing system already designed for that type of lighting
craigsez
Novascotia,Canada
I have a cpl blue 4" strips i wanna put in my box..Like to have it live in the cab switch just to light up the box on those nice summer show off evenings..
DaKing
6.4 HEMI
nateinva
Central Virginia
2011 1500 Laramie CC
5.7L
how does the tape hold up? is it stuck on plastic or did you stick it to actual metal?
The strips are solid. They use a 3m tape similar to what youd find on the window visors.
I have mine stuck to the bed rails under a BakFlip cover.
BBRAM2500
stony plain Alberta
I did exactly what da king did with Walmart led bar and I just wired it with a relay to the bed lighting on the third light
crash68
ACME product engineer
Administrator
3.0 EcoDiesel
What's the problem with using the +12V from the trailer 7 pin harness? It's just used for auxiliary lighting on trailers and to recharge the trailer brake break-away battery(if the trailer is so equiped).
I've done two such lighting projects using the trailer wiring power, cap and bedrail lighting with no issues.
Make sure you clean the surface really good with isopropyl alcohol (rubbing alcohol) before you stick the lighting strips up to the underside of the bedrail.
R/T_Fire
Pleasant Grove
Nothing, that is why i said personally i wouldnt recommend it.. you can draw power there and put a switch in but why not add it to the cargo light circuit and use what is already designed for lighting the bed and not adding another switch to do the same is all. Just personal preference
DaKing
6.4 HEMI
I wired to the factory switch cause it was there, and make a factory look.
My original wiring plan was to tap in to the trailer connector. Run a fused power to each light. The, use a "hood pin" switch to turn on the lights, when the gate is open. So basically the lights would get 12V Positive all the time, but switched ground, by opening of the gate. The issue was finding a sopt that would work.
