Bulb list for 4th gens
Kinetic
Using info on this forum, Boosted Motorsports and some other youtube videos, i changed out some bulbs on my 2017 Ram 1500. So far no problems!
https://www.amazon.com/gp/product/B01EJKIUP8/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1
Reverse Lights
Cargo Lights
3rd Brake lights
https://www.amazon.com/gp/product/B0142WSTJA/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Passenger Light in back seat
https://www.amazon.com/gp/product/B071GBJ9ZH/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Fog Lights
https://www.amazon.com/gp/product/B00JRE38EA/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1
Map Lights
Licence Plate Lights
Wheel Well Lights
All these bulbs were plug & play, I did nothing other than plug them in and I have had no warning lights or any other problems, It has been about a month now. Thinking about doing my headlights next :)
I can now confirm the bulbs for reverse lights, back seat, map lights, and license plate lights do not work on 18's. I'll be looking for the correct bulbs and giving these away to friends .
SixFOURhemiHD
Ghost Rider
Alabama
6.4L 392 Hemi
4th Gen LEDs
Reverse - 921
Cargo Lights/Top mount break light - 921
Map lights - 921
Dome light - 4410
License plate - 194
Tail lights / Brake lights- 3157
Front turn signal / Side marker - 3157
4th Gen HIDs
Quad lights
High beams - 9005/HB3
Low beams - H11
Dual lights
High/Low - H13/9008
Fog lights
(regardless of headlights)
H10/9145/9140
Need to add Roof Clearance Lights - 194
Also, the map lights are not 921s, they are 194s, I don’t think 921s would fit inside the lenses, even though thy have the same base. I could be wrong but I installed 194s and they work.
troymz
Anyone have an idea of what bulb type goes in the vanity mirrors? 2018 ram 1500
theAZnut
California
Hemi 6.4L
Hi Guys,
After reading a bunch of stuff on the Forum and the WWW, I just decided to buy some LASFIT Canbus Error Free LED bulbs for the interior map lights, the rear dome light, the reverse lights, the cargo roof lights, and the third brake lights. I bought them from Amazon and they seem to all have a one year warranty. I think I spent $75 all in and have an extra 3rd Brake Red LED bulb as well as a Rear Dome Light LED Bulb for the future if needed.
I installed the interior bulbs (they are almost to bright in the front), the reverse (big improvement), and the license plate bulbs today.
20180830_175145.jpg Dome Light LASFIT Canbus LED 42mm Bulb.jpg License Plate & Map LASFIT Canbus LED Bulb (package front T15).jpg Map Lights LED (pic2).JPG Rear Dome Light (pic2).JPG
I will install the roof cargo LED bulbs and the LED 3rd brake light bulb (as well as do the leaking 3rd brake light seal upgrade mod).
So far so good with not chimes or messages in info center in cluster.
I hope this was a bit informative and helps anyone wondering but i did watch and lookup any and all forum posts and YouTube videos to learn a little as well
I will have to get the brake/turn signal LED bulbs at a later date as well as work on the front end exterior LED bulbs
REAR DOME LED LIGHT BULB (Canbus Error Free):
LASFIT 42mm LED Festoon 211-2 212-2 569 578 Bulb Canbus Error Free 400LM 6000K Extremely Bright Use for Raer Dome Light, Xenon White (Pack of 2)
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
REVERSE LED & CARGO LED OUTSIDE ROOF BULBS (Canbus Error Free):
[4-PCS] LASFIT 912 921 T15 906 2835 W16W LED Light Bulb SMD 3030 Chipsets 1400 Lumens Extremely Bright for Car Reverse Backup Interior Dome Trunk Lights, Polarity Free, Xenon White
https://smile.amazon.com/gp/product/...1?ie=UTF8&th=1
-OR- (if you only need the license plate bulbs
LASFIT 194 168 T10 192 2825 W5W LED Bulb Canbus Error Free, Non-Polarity 400LM 6000K Extremely Bright for Dome Map Courtesy Door License Plate Trunk Cargo Lights, Xenon White (Pack of 2)
https://smile.amazon.com/LASFIT-Non-..._&dpSrc=detail
3RD BRAKE LIGHT LED BULB (Canbus Error Free):
LASFIT 912 921 T15 906 2835 W16W LED Light Bulb SMD 3030 Chipsets 1400 Lumens Extremely Bright for Car Center High Mount Stop Brake Lights, Brillant Red(Pack of 2)
theAZnut
California
Hemi 6.4L
Here is a few more pics of the LED Bulbs I did on the back end outside of my 2018 Dodge Ram 2500 4x4 Hemi 6.4L (License Plate and Cargo lights)License Plate & Map LASFIT Canbus LED Bulb (package front T15).jpg License Plate LASFIT Canbus LED Bulb T15.jpg DSCN4043_LI (2).jpg LASFIT 921 Canbus White & Red LED Bulbs For 3rd Brake Light & Cargo Lights (Package FrontsS).jpg LASFIT 921 Canbus White LED Bulbs (Cargo Lights).jpg
theAZnut
California
Hemi 6.4L
Here is a few more pics of the LED Bulbs I did on the back end outside of my 2018 Dodge Ram 2500 4x4 Hemi 6.4L (Reverse Lights)Reverse Stock 921 Bulbs.jpg Reverse Set New LASFIT  921 LED Bulb.jpg Reverse LASFIT 921 LED Bulbs (bad pic).jpg Very Bright licnse Plate LED Bulbs (Pic 1).jpg Zero Messages After LED Bulb Install.jpg
Ramitiner
U.S. ARMY VETERAN
NJ
Fog lights
H10/9145/9140
Hey guys, just want to confirm that as long as it has any of these numbers it, will work, right? ordering lasfits and need to be sure as their LA series only has 9145 listed
WTM75
Upstate NY
3.6 Pentastar
Reverse Lights
Cargo Lights
3rd Brake lights
Fog Lights
Map Lights
Wheel Well Lights
Update- Changed out my cluster to the 7” EVIC and now it throws a code for the License Plate lights Out. Apparently, the premium cluster is more sensitive.
theAZnut
California
Hemi 6.4L
I decided the LASFIT 42mm LED Festoon 211-2 212-2 569 578 Bulb Canbus Error Free 400LM 6000K Extremely Bright Use for Rear Dome Light and the LASFIT 194 168 T10 192 2825 W5W LED Bulb Canbus Error Free, Non-Polarity 400LM 6000K Extremely Bright for Dome Map Courtesy Bulbs were way to bright for real world use. They almost hurt your eyes at night with a total of 600 lumens of output at night at 6000k color. they did perfectly match the outside bulbs color and intensity though...
I just installed 5000k Color V-LED 80 Lumen white bulbs in the map lights and they are perfect and still pretty white in color and not yellow. Amazon.com: VLEDS 2pcs 80lm 5000K White 194 T10 2825 360° Long Life 1 LED Bulb: Automotive
I also installed a V-Led 5000k Color 230 Lumen (although says 170 Lumens as measured) bulb in the rear cab light and they are much nicer in intensity and color and match the front ones perfectly. They don't scare you awake or hurt your eyes at night. Amazon.com: VLEDS 1pc 230lm 42mm 5000K White 211 212 560 578 6411 360° Long Life 24 LED Festoon Bulb: Automotive
I was hoping to get the V-LED 4 row LED High Output bulb but it is not on Amazon and I think it would be a bit brighter but not necessary. WHITE HIGH OUTPUT 48 LED 360° 42MM 211
Neither of these bulbs say they are canbus but I have no messages or indicators they are incorrect or out in my info center in the dash and it has been days...
Oh, Somewhere in a video or this forum I learned this handy trick to remove those bulbs. I can't take any credit for this handy piece of knowledge though...
20181107_134213.jpg 20181107_134221.jpg 20181107_134243.jpg 20181107_134347.jpg
556Hunter
Montana
Any suggestion for a license plate LED that is the 6000k white but not obnoxiously bright?
cubmedic
Danville, Va
So those of you running the Lasfit LED's have you had any problems with them?
reb0957
Broussard, LA
5.7l
Has anyone had any luck with the Sylvania LED's? I am fixing the gasket on the center stop light and was going to but the Sylvanias because they are in the store. But I will not feel like taking this light apart again in the rain.
Thanks!
Hookie
Eastern Ky
Reverse Lights
Cargo Lights
3rd Brake lights
Fog Lights
Map Lights
Wheel Well Lights
Did you use a Canbus Error Free Anti Flickering Resistor on the fog lights?
WTM75
Upstate NY
3.6 Pentastar
No, I did not. All I did was install the bulbs. All the bulbs I listed worked perfect, until I installed the premium cluster. Then I got the License Plate light out, everything else still worked perfect. I fixed the license plate light out with the AlphaOBD.
1500ram12
5.9L Cummins
Hookie
Eastern Ky
It helped a little but still no where near the way it should be. should I try a H10 9145 9140 9050 9155 LED Fog Light bulb?
1500ram12
5.9L Cummins
Best bet would be to use whatever size came stock. I do remember with a little trimming of the locking tab a 9005 will fit
malsup83
Arkansas
What bulb is used for the running lights. I can't stand the yellowish bulbs. Just about to order all leds.
2023RamWarlock
