Change the background color of your Ram badge.
AustinB
Banned
San Diego, Left Coast
I originally posted this in the exterior section. But I wanted to give my thread a proper burial to the bottom, in the right section :)
So I've been wanting to change the background color of my ram badge for some time now. The front badge was accomplished by disassembling it, paint, clear, reassemble with epoxy. But the rear badge is an even bigger challenge, with it being one piece.
First things first, I do not believe in using plastidip on my truck for anything, other than a temporary idea of how something would look, and then remove it asap. I have a history of body repair/auto painting, and I'm all about a permanent, professional-looking final product. With that being said, I entertained the idea of taping off the ram, properly prepping the background, paint, clear. But it would be a nightmare to do this perfectly, and not have a risk of peeling/chipping down the road.
This is where the dilemma started. About a month of researching, trying to pick the minds of manufacturers (which do not give up their techniques, because $), and looking at the confused faces of the hobby shop employees when I walk in with a Ram badge. No one had any answers. So I used my own brain and the results met my expectations.
Minimum supplies needed. (If you have tender hands, rubber gloves are recommended)
1) Pick up some pourable epoxy used for bar tables (ie. the tables with the beer bottle caps inlay). This should be a two part with the resign and activator, and can be ordered online or picked up at Lowes/Home Depot.
2) The hardest part was learning how to safely change the color of the clear epoxy. Research shows that acrylic paint has no effect on the epoxy and final result, which is perfect because you can get/mix any color imaginable without any transparency. I chose to use the best quality paint I could get from the hobby store. Which was a variety pack so I could show you guys how it turns out.
3) For mixing, not a whole lot is needed, but you don't want to end up short. The mix is 1:1, so I just filled up to the first line at the bottom of the dixie cup. So two cups, one with the activator, one with the resin.
Before mixing the two, I added the color to the cup with resin. It doesn't take much, I used about 4 drops of paint, for the white I had to use about 7.
4) Stir in the paint well with popsicle stick (when stirring, try your best not to make air bubbles). Once you have the color mixed in, pour in the activator and stir again until completely mixed. Be sure to scrape the edges and bottom of the plastic cup, ensuring it all gets mixed evenly.
5) Now pour the contents of that cup into another empty cup. After throughly cleaning the badge (I used rubbing alcohol), you're ready to pour in the epoxy. This takes A LOT of patience. Take your time, pour slowly and be sure not to pour too much. You can lightly blow on it to fill in the crevices. The badge must be on a level surface . (I used some stacked drink coasters because of the pegs on the bottom of the badge.)
note: the grill badge must be disassembled, and sealed back together (silicone, hot glue, etc..) Prior to pouring.
6) Once it's poured, blow gently on the epoxy, it will release all the trapped air bubbles. Once you're satisfied, place a cover over the badge to prevent dust or other weird **** from making contact. I used a large plastic mixing bowl and just put it over the badge upside down.
7) Wait about 24 hours and it is now safe to touch, but try not to. If you got any on the chrome, this is the time to remove it. Use an xacto knife and gently scrap off your mistake. Wait two more days before mounting it back on your truck.
42e752e2bba9a274d8dfe55bd1166c86.jpgf6098defbb077769b0158bd19f98cc14.jpg9a1e67010959a913bf8514dcf09f89ca.jpg
72c96f5e7f15a3620af5c325a0a855f6.jpg367455f372e22231f8a43fba0b83ae35.jpg746ccdc3868b7cd166a20933553776cc.jpg
IMO
gofishn
Iowa
hemi 5.7L, 345 cu in
Can't do it.
Wife ever gets me into a Hobby Lobby, I will never get out of taking her, again.
She goes to much, as it is.
AustinB
AustinB
Banned
LoL. Can pick up a soap making kit and some yarn.... Just get her to do it for you.
IMO
clifford15
CTD
Nice work! Got to go to Hobby Lobby to check out the car section again. Its been a while.
sbarron
Wasilla, Alaska
Only if you hate your cash.
AustinB
AustinB
Banned
Well I'm going to check it out, maybe tomorrow... I went this past sunday...only to find out they're closed on sundays. I hate that, like when I pull up to the menu at Chick-fil-A.
IMO
yanclanman
That looks so awesome. I love your white on white Ram.
crazy_luck
Minnesota
Might have to look into doing this sometime this summer...
Great write up!
AustinB
AustinB
Banned
Went to the hobby lobby today.. I can definitely see how easy it would be to blow some cash in there.. Some cool stuff for sure.
IMO
Dbush36
Fort Wayne IN
Doing this today. I painted the inside of mine with the liquid duplicolor color match and it lasted about 3 weeks and it cracked... I have no background in paint so I just did what I thought would work... This looks to be a lot stronger!!!
Thanks for the post
AustinB
AustinB
Banned
Thanks for the post
Good luck, hope it turns out good! Post pics!
IMO
Dbush36
Fort Wayne IN
AustinB. I'm having trouble coloring the epoxy I've made two batches so far and both are very transparent once I pour them into the emblem the first batch I just use a few drops of paint like you said the second batch or use a lot more just to see what would happen but I can still see the black background through the epoxy... Any suggestions?
Dbush36
Fort Wayne IN
Acrylic...
Color traditions is the brand
AustinB
AustinB
Banned
When I say "drops"... Referring to holding the tube upside down, gently squeeze until a clump falls out on its own.
The only thing I can imagine is not enough acrylic/too much epoxy.
Add until there is zero transparency.
IMO
Dbush36
Fort Wayne IN
Ok I'll try another batch tonight... Thanks
