Lttlcheeze
- Jul 30, 2014
- 27
- 5
- B-More MD
- 2012 Big Horn
- 5.7 Hemi
I'm gearing up to change all of my Fluids. I bought her with a little over 50k and am now at about 110k, and plan on changing all of the Oils/Fluids soon, and could use some advice. And just FYI, I'm not sure any of this has been done before.
Planning on changing:
Transmission Fluid
Transfer Case Oil
Diff Oil (F&R)
Coolant
Power Steering
Brake Fluid
Along with:
Sea Foam in Oil & thru Fuel System
Serpentine Belt
Spark Plugs
Adding a Cabin Air Filter
Fuel Filter
OK, and now my issues:
1) I'm not having luck finding the Fuel Filter, any suggestions??
2) What is the preferred Oil Brand? Lucas, Amzoil, Redline, Royal Purple, Mobil, Castrol, Pennziol, Motul, Bel Ray (my personal preferred choice for Motorcycle Oil Products)
3) Thoughts on Fluid Changes:
--I'm definitely planning on doing the DIY Trans Flush.
3A) Should change all the fluids (Transmission, Differentials, Transfer Case, Coolant) again in a few days, because of the mileage? Thoughts?
3B) Thoughts on using SeaFoam Trans Tune, as a Pre-Cleaner before doing the Transmission Flush?
Transmission Fluid
Transfer Case Oil
Diff Oil (F&R)
Coolant
Power Steering
Brake Fluid
Along with:
Serpentine Belt
Spark Plugs
Fuel Filter
