Is the proper way to remove the thermostat?
Can I drain the radiator, fill with distilled and run it...repeat till clean. But at that point the engine is full of water...and winter is coming.
Can I remove the return line coming from the heater core and stick a hose in the radiator and run it till clean water comes out of the return? But again I'm left with all water in the system
Can I add G-05 to (what I assume is) factory fluid?
I would like to get rid of all old fluid and add new, but I guess I would settle for a radiator drain and fill if the flush is too involved
