Hemi395
- Mar 18, 2013
- 8,987
- 15,663
- Cape Cod MA
- 2013
- 5.7 Hemi
I did exactly what you guys suggested and pulled the bolts one at a time and added antiseize to the threads so thanks for that suggestion. I'll recheck them in a week or so after some heat cycles.
So while I was under there I figured I'd check my MH trans pan bolts. Good thing I did because 3 of them were essentially coming loose and the rest were not torqued to 105 in/lbs. So those that are running the MH trans pan I would check torque on those bolts.
