DIY - add Auxiliary switches to a 2016 RAM 2500 Tradesman
Canadian Mopar
Alberta
2017 2500 SLT
6.4L HEMI
Just to clarify, you are saying that if I found a parts truck with the Aux switches installed I could wire it up myself?
Yes, you would need the "dash" harness (or at least the fuse box from it) and the switch bank (if it has the same upper switches as yours) from the donor truck.
Special K
AL
HEMI 6.4
I would definitely be interested in seeing the part numbers, pictures and a write up.
kegger
3.6 pentastar
For the relay box off amazon, the larger "relay" what can it be used for? just wondering if i could pre wire it in and use it later if need be.
Special K
AL
HEMI 6.4
Any. Chance you could share the pictures of how you installed your setup?
marc cormier
qc, canada
pentastar
i did this mod last week on my 2019 1500 classic. i buy the switch panel online and made the fusebox and wiring myself. activate the option with alfaobd and voila. if you know how to properly connec fus and relay it's an easy job and work great
marc cormier
qc, canada
pentastar
kad
Hudson Valley, NY
5.7L HEMI
Which switch panel (part number) did you use and what options did it have?
-K
tnctx02
Texas
2017 RAM SLT
3.6L Pentastar V6
Canadian Mopar
Alberta
2017 2500 SLT
6.4L HEMI
-K
The only part number I am finding for my 2017 Ram 1500 is 68231819ad. But it says it is for a 2500 on all the Mopar sites. Factory one in truck has traction and tow/haul only.
Is there one for the 1500 or will this work? Found it on eBay for $75
https://www.ebay.com/itm/2015-18-Do...122454&hash=item2d0df69722:g:FOEAAOSwHmhe38W5
Benny posted a doc with all the different switch banks over in the vendor section. All the switch banks can be used on 1500-5500, no difference except the different options.
https://www.ramforum.com/threads/auxiliary-switch-bank-application-chart.149033/
RamRodJay
Tucson, AZ
Hey everyone, first post here and reading up on this thread. Sorry for the noob but maybe complicated question im about to ask.
I have a 2014 Ram 1500 SSV (special service vehicle), and it came with the upfitter package and the VISM under the dash. I have just the one upfitter plug in the engine bay, jthe dark gray one so I can run the aux panel for sure, just aux 5 will be useless since i dont have the PTO option. I understand I need the aux panel from a 2500+, but do I need the upfitter wiring package, or will this all be plug and play once i swap aux panels, and run 4 new wires from the gray plug in the engine bay? currently its the blank bottom row.
marc cormier
qc, canada
pentastar
on non pto truck the 5th switch just become a regular aux switch like the 4 others. and there is no plug and play harness for these switch, if you don't have it from factory there is no wiring present, it's completely do it yourself
meu_21
Ontario
3.0 EcoDiesel
I have a 2018 RAM. I installed my switches and used alfaobd to program with the bypass cable, but my switches don't show up on the screen by just changing the "Cust.Set. Menu 1. Auxiliary Switches CSM Present". What setting did you use?
marc cormier
qc, canada
pentastar
first, i don't know if you already work with alfaobd so just to be clear, everytime you change a setting in your ram you need to turn the key off and wait up to 5 minute for the truck computer to go in sleep mode, then the change will take effect after that.
this setting should be the only one. the option will be in the instrument cluster screen under the commercial setting. you need to enter a pin cond to access these setting. the default pin code should be 0000
meu_21
Ontario
3.0 EcoDiesel
Yes, I initially activated it that way, but I couldn't get the radio buttons (check marks) to switch between Battery / Ignition, and Latching / Momentary, It would always default back to Ignition and Latching. Otherwise they were hooked-up correctly and I've tested them and work.
kegger
3.6 pentastar
Need a bit of guidance here guys. I finally got the relay box in the truck but it's not working. I have power to the relays on 30 and 87 but when I hit the aux button inside the truck nothing changes. I don't get power on any other pin of the relay. I've checked and the relays are working correctly. If I put power to the aux output the fogs light up. Did I wire something backwards!? From the switches inside theIthe truck I get 9.1 volts if I turn in any aux button and the power goes away on that button only. I don't know what to do other then pull the box and see what I may have wired wrong.
Any help would be awesome.
Moparfanatic21
U.S. Marine Vet - 0321, Now a Doctor...of Vehicles
The switches switch the ground not the power
kegger
3.6 pentastar
I get the switches should be grounded. What's happening is there is zero power on the aux switches with the truck on. When I hit aux 1 there is still nothing but on pins 2,3,4,5 there is positive power. If I turn off aux 1 there isn't power on any pin. If I turn on aux 2on the panel there is zero power on pin 2 but positive power on 1,3,4,5......ect all the way across. I just double checked my wiring against the picture posted earlier in the thread and it all seems right. Only thing I can think is there is something wrong with the panel itself.
gdwillet
US
Does anyone on here know how I can test my auxiliary switch panel? I think I got a bad panel as my tow haul and traction control buttons light up and work properly but my 5 aux buttons do not light up or work. Any help is appreciated!!
Sent from my SM-N975U using Tapatalk
