DIY: 2013-2014 OEM Steering Wheel Audio Control Install
yohan
2013 Ram 1500 ST Quad 4x4
V6 3.6L Pentastar
The new wheel doesn't have the gear buttons. Do you need those? If so you could take them off your current wheel and put them on the new one before you install it.
The new wheel will have the correct harness inside it, you should be good to just swap if you don't need the gear buttons.
If you use the stock RA1 bezel be prepared to push on it kind of hard to get it to click in place over the RA4. I ran like that for a bit before we were able to make the conversion harnesses to use the correct 8.4 bezels.
I wonder what this button does?
I do need the gear +/- .. haven't quite figured out what they do other than preventing upshift passed the selected gear but thats for another thread.
yea I will just pull the gear buttons from my old steering wheel. I got it for $125CAD+shipping, stoked to get this mod going!! Need me some hands free.
dsexpress
2012 RC Express (sold) 2017 Ram RC Express
A little confused on the wiring. Obviously the 2 wires for the switches, but the rest of it...especially the long flat plug in what does that hook too?
cgeorgemo
cgeorgemo
Joplin, MO
3.6 Pentastar
The long flat plug sounds like the one that connects to the controls on the front of the wheel for the cruise control, gears, evic, and hands free controls.
dsexpress
Yep I figured it out. The wiring is replaced by the new harness, not added along with the other.
dsexpress
By the way...thanks for chiming in. I was in the wrench mode at the time.
It works beautifully, and I really like the leather wrapped wheel.:happy107:
JRust
Oregon
EcoDiesel
2012 heated steering wheel with audio controls
Hey I am hoping I didn't blow it. I bought a wheel off a 2012. I looks like the right wheel but I see here it says 2013 & up? Also do I need to add wiring for the heated wheel to work as well?
Gear Jammer
Yacolt WA
Cummins
Do you have to have the dealer flash the correct code into the computer for the radio controls to work? I read somewhere that on the 2016 and up trucks you do, but now I can't find where I read that at. I have the Uconnect 5.0 if that makes a difference.
R.L.K.
Bristol , Tn.
No code required .
Radio type doesn't matter .
R.L.K.
Bristol , Tn.
R.L.K.
Bristol , Tn.
On second thought I should've said :
Nocodes required .
( OEM ) Radio type doesn't matter.
DeereGuy
Pittsburgh, PA
^^^What he says^^^. Mine asked if there was a wife forum that I could post to lol
ScottD
2016 Ram 2500
Hey all, I am new to this forum. I found it specifically looking for adding radio controls to the wheel.
The write up is great, but I want to make sure this will work with my 2016 Ram 2500. I have the small touchscreen radio w/o nav. I asked the dealer about ordering the parts and installing the parts listed. They told me that my vin does not show these parts as options, so they cannot guarantee they will work once installed. Can anyone confirm for me my truck is capable of adding these controls?
R.L.K.
Bristol , Tn.
Yes , you can add the audio controls Sir !
There's lots you can do to your truck that your dealer is unaware of my friend .
Such as , upgrade to the RA4 Radio ( large touchscreen radio )
Install the premium instrument cluster .
Install factory backup camera , the list goes on &on
ScottD
2016 Ram 2500
Thank you very much for the help.
R.L.K.
Bristol , Tn.
Oh , and welcome to the forum Sir!
From Bristol Tn.
Suggestions .... look @ the 4th Gen DIY Section & Don't forget the ( stickies )@ the top .
Read lots , post lots and help others when you can !
1Popeye
