You are welcome I'm glad it was helpful.Did mine last night, this was VERY helpful.
Thank You
Sounds like the one I have. 5" touchscreen. That's the Uconnect 5.0.what radios does this work for? I have the smaller touch screen w/o nav, but does have bluetooth
Yes it works great! I have the Uconnect 5.0 in my 14 Express and
upgraded to the leather steering wheel and the radio switches. It's totally plug and play.
The wiring for the audio/uconnect/cruise/gear selector all connect to the same harness. I didn't check to see where it went but I thought the Axxess ASWC-1 adapter was installed at the radio wiring harness not the one coming off the steering wheel.I plan on adding the SWC to my 2014 Tradesman. I will have to use the Axxess ASWC-1 adapter with my aftermarket stereo. One question I have is where does the wiring harness from the steering wheel connect? I took a quick look under the dash and the wiring harness from the steering wheel goes into a larger bundle that is wrapped with black cloth tape. There is a connection that is covered with a grey foam padding coming off the larger bundle.
A photo of where the harness connects would save me some time unwrapping the bundles of harnesses. This tutorial is great, I'm just trying to save a little time on my install.
Thanks in advance.
Ok sorry, I have no idea where it is at the dash. The harness I ordered plugged into the adapter on the steering wheel.Sorry for the confusion, the ASWC-1 does connect to the stereo connection. What I was wondering was where the new steering wheel harness connects at the dash end. The wiring goes from the steering wheel into a larger bundle of harnesses under the dash. I was just trying to figure out where in connects under the dash.
Where's the best place to buy the parts for this mod, other than the dealer??
Thanks!I placed an order with https://www.partswebsite.com/moparonlineparts/
last week. The back cover for the steering wheel is on back order so I haven't done the mod yet.
All mine came from allmoparparts.com they weren't back ordered when I got mine. I've ordered a lot of things from them and they have been top notch.Where's the best place to buy the parts for this mod, other than the dealer??
The holes for the switches are in the back cover from the factory.Ok, more questions:
The Black back cover 1YH75DX9AC ($22.02), in pictures, it does not show the opening cut out for the audio controls. Are the opening there, but just not shown in the picture, or will I need to Dremel the openings for the audio controls?
Next, with removing the airbag, after taking all necessary steps. The airbag is held onto the steering wheel buy those black studs. The parts on the airbag look like they are U shaped. To get them off, you just use a screwdriver to pry/slide the U shaped things off the black studs??
Thanks, just wanting to get all the facts before diving into this
I used a screwdriver to get the airbag springs off the studs. Be patient it can be frustrating to get them off the first time you try. They are pretty stiff and not being able to see them makes for a frustrating job.
