cgeorgemo, I felt like I owe it to you. Here is my After Action Review:
Honestly, airbag clips weren't my most frustrating part, they came off pretty easy.
I got the wrong steering arm puller, need the ones with the hooks to pull the steering wheel off, but I did give it a shot and the steering wheel did wiggle off.
The top right torx screw on the steering wheel while it is facing me, would not come out and it got stripped. I was able to get the wiring behind it anyway.
I went to put the left side controller in and it popped out of its housing. Freaked at first, but nothing appeared broken so I just snapped it back together.
Now putting the steering wheel back together, the 2 phillips on the back of the steering wheel at the bottom, was snugging them up and they stripped.
Putting the steering wheel back on, the clock spring was moving a little bit back and forth after I hooked the wires up. Was concerned I screwed that up.
Anyway got the steering wheel back on. Left the air bag off and reconnected the negative terminal to check if controls worked and they did. Yeah!!
Now concerned about that clock spring moving, I took my truck for a test drive on the interstate. Cruise controls worked fine. Came home, backed up, lines were straight when backing up.
1) Now after reading that does it appear that I didn't mess with the clock spring too much to screw things up, since cruise control worked fine and the back up camera line were straight with the tires when backing up??
2) Any idea on how to fix those 2 stripped phillips heads on the back of the steering wheel??
Overall, I would say it was a success. After I hear from you, to make sure everything sounds fine, I will disconnect the negative battery terminal again and install the airbag.
Again, your help help has been most appreciated.
Thank you
