Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > 4th Gen DIY
4th Gen DIY
DIY: 2013+ RA3/RA4 8.4" Radio Conversion Upgrade
This is a discussion on DIY: 2013+ RA3/RA4 8.4" Radio Conversion Upgrade within the 4th Gen DIY forums, part of the 4th Gen : 2009 - Present category!
This thread has been created to show how to perform the 8.4 head unit upgrade project. Originally Posted by Mpgrimm2 ...
Like Tree1237Likes
Reply
Old 12-27-2015, 11:47 PM   #1 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2014 Big Horn Crew
Engine: HEMI 6.4L
Default DIY: 2013+ RA3/RA4 8.4" Radio Conversion Upgrade
Managed to re-create the deleted thread posts from googles cached pages with help from 1500ram12!
I take NO credit for any of this, just wanted to sum this info up for everyone here. All credit goes to Getupkid, Duneflyer, Mondo161, Cptwing, PJW67, and others for getting this project started and all their research.
Be sure to thank Cptwing and Indaram for these original posts wherever you see them as well as the original folks who did all the work to figure this out...
(again, I had nothing to do with it, I'm merely the tech secretary here that still had some files!)
Originally Posted by Indaram
Original post recreated/edited below
Sponsored Ad
Register to remove this ad.
__________________
MICHAEL
SUPER MODERATOR
2014 BIG HORN CC / 6.4L HEMI
AFE / ARMA COAT / BFG KO2 / DIABLOSPORT / HEMIFEVER
MAGNAFLOW / N-FAB / PIAA / PRO TECH / TUFF COUNTRY / WALKER EVANS RACING
MADDOG is offline   Reply With Quote
Old 12-28-2015, 09:51 PM   #2 (permalink)
Mpgrimm2's Avatar
Ram Year: 2013 SLT Crew
Engine: 3.6L V6 Pentastar
Default
Converting a 2013+ (thru 2016) RA1/RA2 MTC bezel
with 7 speed blower
to a RA3/RA4 MTC bezel and Radio.
NOTE:
There is a confirmed working mod for those that have a 4 speed blower, see Cptwing's posts 3-8 for extra steps/parts for a 4 speed fan conversion.
Parts Required For MOD:
01. 8.4 Uconnect Radio (VP3/RA3 - Non-Nav) or (VP4/RA4 - Nav)
** For Compatible RA4 Radios see here. **Check car-part.com, Schram, ebay, etc.
02. SINGLE ZONE OEM 8.4" (MTC) BEZEL: 1UJ96DX9AF (AC, AD, AE, etc)
** Optional: DUAL ZONE 8.4" (ATC) BEZEL, while not preferred, will work. See post 16
03. Base to 8.4 Radio Conversion Harness (7 speed Fan specific models):
. . See below to make your own in standard or extended length
. . (or get one from getupkidharness .com )
NOTE: See Posts 6 & 7 (from 4spd conversion) for pictures of factory HVAC Module location using extended harness.
04. HVAC Control Module: 68268186AA (etc) (7 speed Fan specific models)
** (also replaces 68183973AA, 68183973AB, 68183973AC, 68236772AB, etc. See here)
05. 911 Error Fix/Cellular Fooler Plug: (or SharkFin Antenna mod)
. . See note 1 (below) to make your own or get one from OemAutoPartsco, or similar vendor.
Quick Instruction Sheet References:
- 2013-2016 8.4 Conversion for 7 Speed Fan Trucks 9-8-16.pdf <----- RECOMMENDED READING
- 2013-2016 Ram Radio Removal 6-27-16.pdf
- 2013-2016 Ram RearView Mirror (w/mics) Upgrade & Harness install 7-8-16.pdf
Originally Posted by Mpgrimm2;
Pre- install recommendation to save any headaches...
- pop the 8.4 radio in with the existing bezel to make sure it works.
- resistance check (ohm out with a meter) the conversion harness against the schematic below to make sure it's good to go. (Whether you purchase it or make it yourself, since they are handmade and mistakes do happen)
Optional parts
- RA2 style Manual Dim Mirror w/mics: - 68102484AA (Recommended)
. . . (Man. Mirror Mount Covers if Needed: Upper - 1ZA38DX9AA and Lower - 1YW11DX9AA )
. . . or 911/Assist AutoDimming Mirror: - 68096091AF (AutoDim req's Sales Code)
. . . (Auto Mirror Mount Covers if Needed: Upper - 1ZA39DX9AA and Lower - 1YW13DX9AB )
- Mirror Header harness (Standard): - 68207372AB
- Mirror Header harness (w/Clearance Lts): - 68186009AC
- Antenna Cable Body Cell & SDARS "QUAD/CREW" (Rear cab Ant): - 68148279AD
- Antenna Cable Body Cell & SDARS (Front Cab Ant): - 68148260AC
- Antenna Jumper Cable: - 68148258AD
- Shark Fin Antenna: - 5091278AC
- SD Card Media Hub: - 68096428AD
- VR/Phone Button (for steering wheel) - 56054449AA
NOTE 1:
You can omit the Antenna body cable, Antenna jumper cable, and shark fin antenna if you buy the OEM auto parts plug shown here:
911 Vehicle Phone Override Cable
Or you can make your own using the following parts (search ebay and amazon for these)
Farka D connector/Pigtail with 2 to 6 inch lead
10k Ohm Resistor with 5% tolerance, 1/2 watt.
Just solder one end of the resistor to the center wire and the other end to the wire shielding. Tape it up with electrical tape or heat shrink it.
Connectors & Pins to Make Conversion Harness
(Use attached wire diagram and pin-out below)
06. 24 Pin Connector 1: 1318917-1 TE Connectivity | Mouser
07. 24 Pin Connector 1 - (F) Sockets: 1123343-1 TE Connectivity / AMP | Mouser
08. 24 Pin Connector 2: 1376103-1 TE Connectivity | Mouser
09. 24 Pin Connector 2 - (M) Pins: 1376109-1 TE Connectivity / AMP | Mouser
10. 08 Pin Female - Connector: 30700-1081 Molex | Mouser
11. 08 Pin Female - (F) Sockets: 1393366-1 TE Connectivity / AMP | Mouser
Connector/harness Reference:
- 8 Pin Center Stack HVAC Conn 0307001081 AS-30700-000 Series Instruction Sheet.pdf
- 24 Pin HVAC TEconn 025series Instruction Sheet 411-5928_G4.pdf
- Cptwing's harness making notes at Post 9
- Mpgrimm2 Harness Soldering Notes at Post 13
12. 22 or 24 AWG stranded wire
.... (Short harness w/HVAC module behind radio bezel = approx. 18" lengths)
.... (Ext'd harness w/module at factory location behind pass. air vent/glove box = approx. 50" main & 18" 8pin lengths)
13. Crimp tool to crimp the pins on the wire. (Check Amazon & Ebay for wire and crimp tool)
.... See post 12 for some notes on possible crimpers.
Harness Pinout
24 Pin Connecter (2014)
Pin 01 to Pin 01 (Also needs to splice over to Pin 4 on 8 Pin Connector)
Pin 02 to Pin 02
Pin 03 to Pin 06
Pin 04 to Pin 05
Pin 05 to Pin 04
Pin 06 Blank
Pin 07 to Pin 13
Pin 08 on Moves to Pin 2 on 8 Pin Connector
Pin 09 to Pin 07
Pin 10 to Pin 08
Pin 11 Blank
Pin 12 to Pin 10
Pin 13 to Pin 9
Pin 14 to Pin 14 (Also needs to splice over to Pin 3 on 8 Pin Connector)
Pin 15 to Pin 15
Pin 16 to Pin 16
Pin 17 to Pin 17
Pin 18 to Pin 18
Pin 19 to Pin 19
Pin 20 to Pin 20
Pin 21 to Pin 21
Pin 22 to Pin 22
Pin 23 to Pin 23 (Also needs to splice over to Pin 5 on 8 Pin Connector)
Pin 24 to Pin 24 (Also needs to splice over to Pin 1 on 8 Pin Connector)
(Same as original below just re-worked a little)
CptWing - RA4 conversion harness Schematic for 7 speed fan equipped trucks w/MPG2 Edits.jpg
Reference for the different HVAC module pinouts per truck model:
R.L.K., SouthTexan and JoeMcK like this.
Mpgrimm2 is offline   Reply With Quote
Old 12-29-2015, 02:58 AM   #3 (permalink)
Mpgrimm2's Avatar
Default
with 4 speed blower
Its been quite a journey developing this harness along with Getupkid, Duneflyer, Mondo myself and several others. We now have a complete DIY solution for upgrading to the RA4 or RA3 from the RA1 and RA2 radios. The basic Radio is PNP now that we can use the 8.4 bezel and HVAC controls.
There are currently two factory setups for the hvac blower: the 7 speed and the 4 speed.
This is how I understand how the trucks were built, if they were equipped with the RA1 or RA2 radios.
2013 all models have the 4 speed blower setup.
2014 1500 have the 7 speed blower set up
2014 2500 and 3500 have the 4 speed blower set up.
2015 1500 have the 7 speed blower set up.
2015 2500 and 3500 have the 4 speed blower set up
NOTE:
The conversion for the 7 speed factory fan set up while similar is different and involves not only a different HVAC module but the pinouts for the conversion harness are also slightly different.
03. Base to 8.4 Radio Conversion Harness (4 speed Fan specific):
04. HVAC CONTROL MODULE: 68105017AE (AA, AB, AC, etc) (4 speed Fan specific)
05. Fan Motor Power/Resistor Harness: 68048906AA (Req's Modification)
. . (or see DeereGuy's write-up of 00R/T's notes to make your own at roll-up posts 1765-1766)
06. 7spd Blower Resistor: 68048901AA (same as Denso PN 499300-2121) See ebay ad and Post 51 )
07. 911 Error Fix/Cellular Fooler Plug: (or SharkFin Antenna mod)
- 2013-2016 8.4 Conversion for 4 Speed Fan Trucks 9-8-16.pdf <----- RECOMMENDED READING
Optional parts
- PLEASE SEE POST 2
NOTE 1:
08. 24 Pin Connector 1: 1318917-1 TE Connectivity | Mouser
09. 24 Pin Connector 1 - (F) Sockets: 1123343-1 TE Connectivity / AMP | Mouser
10. 24 Pin Connector 2: 1376103-1 TE Connectivity | Mouser
11. 24 Pin Connector 2 - (M) Pins: 1376109-1 TE Connectivity / AMP | Mouser
12. 08 Pin Female - Connector: 30700-1081 Molex | Mouser
13. 08 Pin Female - (F) Sockets: 1393366-1 TE Connectivity / AMP | Mouser
Connector/Harness Reference:
14. Wire 22 or 24 gauge 50.0 inches long QTY of 20
15. Wire 22 or 24 gauge 18.0 inches long QTY of 5
16. Electrical tape one roll should be enough
17. Wire ties
18. Heat Shrink
19. Solder/Soldering Iron
20. Split Wire loom or Nylon Braided Sleeving
Along with this you will need the following:
21. Wire strippers..
22. Crimpers double roll type recommend ratchet type
23. Heat gun
24. Small awl or similar tool to de pin connector
Here is a shot of every thing needed except that some tools are not shown.
The diagram shown below details the conversion harness and pinouts of the various connectors, what is not shown and will be addressed later is how part 1 above ties into it, at pin 17 on the module side.
CptWing - RA4 conversion harness for 4 speed fan equipped trucks Mpg2 Edits.jpg
And after a bit of work and eye strain your harness should look something like this
__________________
Help others out and post about about 2013-2016 8.4AN VP4-NA firmware files and share any 2013-2016 Schematics you may have!
- INFO - 2013-2016 8.4AN FW Notes (RA4/VP4 NA)
- My 2013+ Shared Schematics and other OEM Info
Old 12-29-2015, 03:05 AM   #4 (permalink)
Mpgrimm2's Avatar
Default
GetupKid's - DIY 5.0 to 8.4 Navigation upgrade within the 4th Gen DIY
Cached Pg 9
Code:
http://www.ramforum.com/f75/diy_5_0_8_4_navigation_upgrade-64564/index9.html
Next, the item 05. harness (purchased Fan Power/Resistor Harness) will need to be stripped down to retain only the needed parts. Here it is before mods...
(updated picture, thanks JRG18) of the Fan Power Harness (as purchased) with added notes.
In order to prep the bought harness (item 05), we must de-pin connector i32A (mis-ID'd as 132A), to do this you need to remove (release position) the TPA (terminal position assurance) the red thing. Then using a small jewelers screw driver pry back the locking tab and pull out the wire and pin.
Here is the connector and TPA (From later pictures).
Here is the stripped down unpinned harness item 05, this is what you will use the rest will be discarded.
The stripped down Fan Power harness (item 05) connects to the fabbed Conversion Harness (item 03) on the HVAC module side using the DB/LB 16 gauge wire that goes to pin 2 in the resistor plug. I cut this wire to 25.0 inches long and crimped a female pin on it for the 24 pin connector and inserted it into cavity number 17. Note this is a 16 gauge wire and these pins are not designed for wire this thick so you will only be able to crimp the stranded wire into the pin and not the insulation. The other alternative would be to crimp a pin on a smaller 22awg or 24awg wire and solder them together (or butt splice=less reliable).
MPG edit: I think a 12" (i.e. 22Awg) pinned extension for pin 17 would allow better routing of the wire.
Also recommend not shortening the wires.
Next I cut the black ground wire coming out of the resistor plug to 20.0 inches long and crimped a 10 gauge ring connector onto the end and shrunk wrapped the connection.
The DB wire coming out of cavity 3 of the resistor plug is not to be cut. This wire is to be used to re-pin the existing i32A (mis-ID'd as 132A) connector on your truck. I looped the excess wire back and taped it off.
Here is a diagram of how the harnesses are interconnected (thanks Mondo161):
Here is the complete, combined and finished harness ready to be installed
MPG NOTE: You may find it easier to connect the fan harness' Pin 17 to the conversion harness after both are 99% installed
(its up to you)
R.L.K. likes this.
__________________
Old 12-29-2015, 03:09 AM   #5 (permalink)
Mpgrimm2's Avatar
Default
Now for the install,
First disconnect the battery, remove the following; center stack (and radio for access), cardboard bottom located under lower glove box, lower glove box and upper glove box cavity (door does not need to be removed), passengers side kick panel and passengers side dashboard end trim piece.
Note: Removing/Installing the radio and bezel are not covered here as there are several places on YouTube/internet that cover it (Separate instruction sheet available in post 3).
Mpgrimm2's panel/prep notes:
Radio C1 Connector Latch
Once the center stack and RA1/RA2 are removed, you will need to swap out the old bezel/HVAC controls for the
RA3/RA4 (8.4A/AN) bezel. Set this aside until later.
Lower Glovebox release and HVAC Module Passenger Side dash cover
Passenger Side Kick Panel/Door Sill (PAY ATTENTION)
R.L.K. and ICEChargerRT like this.
__________________
Old 12-29-2015, 03:21 AM   #6 (permalink)
Mpgrimm2's Avatar
Default
Cached Pg 9
Code:
Now for the parts install...
To install module slide it in through the lower glovebox cavity and position the two hex head screw into the keyhole cut outs in the dashboard sub structure and slide forward and tighten see below.
Make sure to orient with plug farthest forward to clear lower glove box when operating, see 3rd photo on this post.
HVAC Module and Factory Location.jpg (Notice the two key hole slots)
Now to install the harness we have to first replace the existing resistor with the new one (part 3), remove the 2 phillips head screws securing the existing one and replace it with the new one using the existing screws.
Here is the existing resistor prior to removal
And here are the two resistors side by side.
I took this picture while mocking up the harness.
CONTINUED ON POST 89
R.L.K. likes this.
__________________
Old 12-29-2015, 03:24 AM   #7 (permalink)
Mpgrimm2's Avatar
Default
Cached Pg 9
Code:
Now to install the harness; unplug the existing connector from the motor and tape it off along with the existing resistor plug they will not be used. Then uplug connector i32A (prev. mis-ID'd as 132A) and replace the wire located in cavity 7 with the one in the new harness, this is the 10 gauge wire you unpinned from part 1.
Reference Locations:
Connector i32A (prev. mis-ID'd as 132A) Before:
Backside view of i32A-7:
Connector i32A (prev. mis-ID'd as 132A) TPA lock and Pin7 Release point:
Connector i32A (prev. mis-ID'd as 132A) with pin 7 wire removed
Heat shrink label
Old i32A-7 taped out of way (prev. mis-ID'd as 132A) :
Here is connector i32A (prev. mis-ID'd as 132A) after I switched the wire in cavity 7
Attach black 10 gauge ground wire to body here or other suitable location.
Plug new harness into resistor and motor.
Here is the new fan harness and upgraded resistor to enable 7 speeds.
(NOTE: The split wire loom will protect the wires from damage by nearby bolt/threads)
Plug harness into module and begin routing it to radio bezel along the same route as the existing body harness and SDAR / Cell antenna leads. The new harness is shown wrapped in corrugated split loom.
Another view:
Here is the harness as routed, looking through the upper glove box.
CONTINUED ON POST 90
R.L.K. likes this.
__________________
Old 12-29-2015, 03:28 AM   #8 (permalink)
Mpgrimm2's Avatar
Default
Cached Pg 9
Code:
Finish routing the harness into the center stack area and plug the 24 pin connector on the harness into the existing 24 pin connector on the truck. Plug in the connectors you previously unplugged and also plug in the 8 pin plug into you new bezel.
Harness coming in behind bezel:
Reconnect battery and test everything and ensure it is working correctly. Reassemble your truck
And here is the bezel installed while testing harness showing all 7 fan speeds, yes that's right the fan now has seven speeds it seems to push more air and is quieter.
And here is the finished job! Every thing on the bezel works as it should. Works perfectly!
Oh and prior to bundling it up I tried two other bezels I had. Both are dual zone with auto climate control. They also worked except for the actual dual zone or auto climate control functions. The drivers side temp switches were active to control the temp, but the passengers side temp buttons did nothing. Otherwise they were fully functional. Just something to think about if you already have an auto climate control bezel and do not want to buy another one. SEE HERE.
Enjoy
Here is a before shot with OEM bezel
R.L.K. and N1ck like this.
__________________
Old 12-29-2015, 03:45 AM   #9 (permalink)
Mpgrimm2's Avatar
Default
Indaram's - DIY - OEM 5.0 Radio to 8.4 Radio Upgrade
Cached pg 5
http://www.ramforum.com/f75/diy_-_oe...96/index5.html
Cptwing's notes for making the conversion harness
First let me say I am no wiring GURU either! But I want to play one on TV.
The numbers are embossed on the connector shells, they are very small and depending on your age and eyesight you may need to use magnification to see them. Not all the cavaties are numbered just the outside 4 on any given connector, but they run sequential. The 8 pin connector is top row 1 thru 4 and bottom row 5 thru 8. For the 24 pin connector shells the top row is 1 thru 12 and the bottom row is 13 thru 24.
If your vision is normal, I would still recommend a nice pair or magnifying glasses to make thing easier on yourself, these connectors and pins are very small and the extra seeing power will come in handy.
As you say it is easy enough, the big key is having the correct crimping tool. The cheap crimping tool that come in the Walmart and Benny's kits will not work. The crimps need to be formed into a double roll, if you just squish them like the cheap crimp tools do they will not fit into the connector shell cavities.
I highly recommend a ratchet type crimper, these are the crimpers I used, they work perfectly, have great reviews and are not that exspensive.
http://www.amazon.com/Iwiss-Crimping...molex+crimpers
First remove aprox 1/8 inch of insulation from the wire
Second click the crimper until it just holds the pin in the jaws
Third slide the wire into the terminal pin until it seats and the insulation is inside the pin...
...Note these pins have two separate crimping sections which crimp simultaneously one the inner one is for the
...actual lead and the outer one is for the insulation.
Fourth squeeze the crimping pliers completely in one steady even motion.
The dies in the jaws of these crimpers are for different wire gauges, in addition each of those is a two section die, one is for the crimp with the just the wire and the other is for the crimp with the wire and insulation. In other words they are meant to be used one way, always slide the pins in from the side. The pins are inserted in the jaws from the side shown in the above picture.
Buy extra pins and do a few practice ones. The pins are very cheap, but the shipping is no, having to place an order for more pins would suck.
You could use quick splices, I assume you mean the 3M quick taps I would rather solder and heat shrink them for a more reliable connection, the 3M quick taps are also bulky as you would need to use 5 of them.
Cached pg 5
Originally Posted by cptwing
Ok I finally figured how to take macro pictures with my camera. So I thought I would share some information and examples of crimping pins and how to identify the cavity numbers on a connector.
Here is a picture of the 8 pin plug that plugs into the radio\hvac bezel along side it is a 20 gauge wire crimped into a pin, not this pin is not for this connector (it is actually for the 3rd brake light connector) , but this gives you an idea of the size.
Next we have a close up shot of that pin along side another pin crimped to 18 gauge wire that is used for the overhead map lamps, notice how the crimps are formed into a double roll and the insulation is crimped separate from the stranded wire. One of these is a factory crimp and one I did using the crimpers in the above post. I did the black one, which in my opinion is actually a better crimp notice the roll on the insulation of the two.
Next is an isometric shot of the 8 pin plug, the red piece is called the TPA (Terminal Position Assurance) or secondary lock. It actually has 10 slots, the outside 4 slots are used to access the locking tabs if you need to remove it. as pictured the TPA is in the unlock position, after all the wires are inserted into the various cavities it is pushed it and locks in place. Note not all connector shells use these, the 24 pin connector shells used to make the rest of the 8.4 conversion harness do not have them.
Next we are looking down on the connector TPA side which is the end that plugs into the bezel. Notice the numbers 1 and 4 on the top row and 5 and 8 on the bottom row.
Next we are looking up at the connector cavity side which is the end that the wires are inserted into. Notice the numbers 1 and 4 on the top row and 5 and 8 on the bottom row.
R.L.K. likes this.
__________________
Old 12-29-2015, 03:51 AM   #10 (permalink)
Mpgrimm2's Avatar
Default
cached pg2
http://www.ramforum.com/f75/diy_-_oe...96/index2.html
The RA3 and RA4 radios contain a sierra wireless aircard (cellphone), used to talk to 911 and uselessconnect. Since your current radio RA1 or RA2 does not have that capability your current antenna does not have the cellular antenna in it.
The one you currently have is called a puck and has one plug used for GPS and XM. The sharkfin has 2 plugs the other being for cellular.
Without the extra cellular antenna the RA3 and RA4 radios will flash an error stating that the vehicle phone needs to be serviced.
Replacing the antenna and leads is more expensive and difficult, so most opt for the dummy antenna as seen on OEMautoparts co. Many on here have made their own dummy antennas.
The benefit I have gotten out of adding the sharkfin is:
With my 2014 radio
911 works
Yelp works
With my 2015 radio
911 works
Yelp works
Roadside assistance thru Ram works
Registration screen comes up and phone dials and connects but I hung up not knowing what they could do to screw up my radio.
Mpg2 Edit:
Reference for the 8.4 Radio Connectors
Cached pg 4
http://www.ramforum.com/f75/diy_-_oe...96/index4.html
Yes the dual auto climate bezels will work, but will function as single zone manual climate control. Only the drivers side temp button will function and the auto function will not work. But besides that it will function the same way.
When I bought mine I paid 75.00 on ebay, for a complete center stack out of a bighorn, including lower switches, brake controller switch, tranny 4x4 switch etc and it was like brand new. This was a while back though when we were trying to figure out how to make this work. Anyway schramm had a bunch awhile back. I have a like new dual zone I might sell if you are interested pm me.
R.L.K. likes this.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
DIY: 2013-2014 8.4 Radio Upgrade cgeorgemo 4th Gen DIY 112 05-04-2016 12:50 AM
Steering radio control conversion? 1999CUMMINS General Discussion 0 12-04-2015 01:06 AM
8.4 radio conversion 911 Error Fix Plug Hootbro For Sale 1 09-27-2015 08:37 PM
help on radio upgrade BigDaddyRam Audio & Electronics 3 08-14-2015 05:27 PM
RBZ Radio upgrade JohnnyDollar Audio & Electronics 0 09-26-2013 08:18 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
