Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > 4th Gen DIY
4th Gen DIY
DIY: 2013+ RA3/RA4 8.4" Radio Conversion Upgrade
This is a discussion on DIY: 2013+ RA3/RA4 8.4" Radio Conversion Upgrade within the 4th Gen DIY forums, part of the 4th Gen : 2009 - Present category!
Indaram's - DIY - OEM 5.0 Radio to 8.4 Radio Upgrade Cached Pg 6 http://www.ramforum.com/f75/diy_-_oe...96/index6.html Originally Posted by Cptwing Not ...
Like Tree1569Likes
Reply
Old 12-29-2015, 02:54 AM   #11 (permalink)
Mpgrimm2's Avatar
Ram Year: 2013 SLT Crew
Engine: 3.6L V6 Pentastar
Default
Cached Pg 6
Not just by size but by type as well. The 52 position radio connector on the 2013 and up actually uses 2 different pin types. To find the correct pins you need the manufacture's part data drawing. In addition the connector drawings will list multiple size pins for the connector by wire size, so to match those up you need the pinout diagram from the techauthority website. The two types of pins used are 2.8mm and .64mm, while these pins are available for different wire size gauges, I have listed only the ones used by Fiat on the 2013+ trucks
Here is the Radio connector
Mouser Electronics - Electronic Components Distributor
For some reason the drawing no longer lists the pin part numbers for the 52 position connector, so here they are.
Here is the data sheet for the radio connector
http://www.mouser.com/ds/2/418/NG_CD..._C1-672647.pdf
Here are the 2.8mm pins
Here are the 0.64mm pins
Cached Pg 7
http://www.ramforum.com/f75/diy_-_oe...96/index7.html
Originally Posted by Mpgrimm2
FYI for the other 4 speed fan conversion folks...
Mondo posted this (here or the z) a while back and is a good reference for those of us that have to use the extra Blower Power Harness with the conversion harness.
@cptwing, can you add this to your post 85 link?
mondo161_2013-2016_8.4_blower_mtr_4spd_convharness_connections_-_mpg_edits_6-20-16.jpg
R.L.K. likes this.
Sponsored Ad
Register to remove this ad.
Mpgrimm2 is offline   Reply With Quote
Old 12-29-2015, 02:55 AM   #12 (permalink)
Mpgrimm2's Avatar
Default
A couple notes on possible crimp tools for those wanting to make their own harness. If anyone else has links/details to affordable ones they used that worked well please let me know and I will update this post...
The link to the crimper cptwing used is/was broken.
It may have been this one by iWiss <--- RECOMMENDED! (the one ebay/DuPont one below sucks)
From the original backup Cam thread..
I believe that is the same mass produced, made in China, crimp tool as the one I use for my Arduino's "Dupont style" 2.54mm pins. It can be found on eBay using a search for "SN-28B crimping tool" for +/- $15. Not sure how well it will work with the harness adapter pins.
The official Amp/TE Connectivity "Pro Crimper III" tool is likely upwards of around $210 at Newark or Mouser.
Manufacturer: TE CONNECTIVITY / AMP
Newark Part No.: 44F8409 (LINK)
Manufacturer Part No 58495-1
Note: A bread bag's Twist Tie with about 3/8" of the coating stripped off, makes a fairly decent pin lock/release tool if you need to pop out pins from the connectors after they have been installed....
Originally Posted by Ramtech2319 View Post
I need to build a harness where did everyone get the connector ends and pins or I did not see them in the post thx in advance
Mouser Electronics, DigiKey Electronics, Newark Electronics, Allied Electronics, Nexus Electronics (NexElec.com) depending on who you can locate in-stock qty and reasonable minimums.
On a related note, just got these cool terminal/extraction tools in and look forward to trying them out making some harnesses soon. Looks like it will cover just about everything. (But too short to be useful for the conversion harness)
Lisle 57750 Wire Terminal Tool Kit https://www.amazon.com/dp/B007WQQHA2..._YGtqybGM633J2
Simple Joys! ��
R.L.K. likes this.
Old 12-29-2015, 02:57 AM   #13 (permalink)
Mpgrimm2's Avatar
Default
MPgrimm2 Harness Notes:
For those of you making your own extended harness, here is a bit of details from mine that may help you...
- Use twisted & soldered connections for splices (blobs can be unreliable)
- Use 1/8” heatshrink over splices vs electrical tape
- (optional) Lightly ‘flow’ solder at all pin crimps for durability and to prevent “pullouts”.
- Some other useful accessories if you do a lot of this stuff:
I use a Weller WES51 soldering iron with ET0 tip, helping hands, Solder Tip Cleaner, Kester 60/40 Solder (or similar),
- Here's a kit of wire with (6) 25ft rolls of 22awg wire with 6 different colors
or (10) 25ft rolls of 22awg wire with 10 different colors (10 Colors to match the schematic)
- Here's Braided sleeving: 25 FT 3/8" Black Expandable Wire Cable Sleeving Sheathing Braided Loom Tubing (main harness)
and 5 FT 1/4" Black Expandable Wire Cable Sleeving Sheathing Braided Loom Tubing (bezel segment)
00R/T's Crimping Notes:
Originally Posted by 00R/T View Post
It's hard to explain how I crimp it, but I'll try.
Strip the wire so the exposed wire is just slightly longer than the wire crimp portion of the terminal.
Set the wire in the terminal so the insulation butts up against the wire crimp portion of the terminal.
Use pliers to press the insulation portion of the terminal (the ears) into the insulation just enough so the terminal will stay in position.
Hold the crimper so the open "mouth" end is facing you.
Place the terminal in the crimper with the open part of the terminal (the fins that fold over) facing the bottom of the crimper.
Align the terminal left-to-right so the insulation side is on the wider part of the crimping die and the wire side is on the narrower side.
Slowly close the crimper and make sure the terminal doesn't rotate.
Close the crimper all the way.
Fix the insulation part of the crimp with pliers if it isn't as round as it should be.
EDIT: On your crimper, the open side of the terminal may go up. You want it facing the part of the die that has the line down the center (like the top of a heart).
Some soldering basics to start:
Soldering pt 1
[url=https://flic.kr/p/WgzjbT]
Soldering pt 2
[url=https://flic.kr/p/WtbjEB]
Soldering pt 3
[url=https://flic.kr/p/WgziNt]
Soldering pt 4
[url=https://flic.kr/p/WtbiYB]
Questionable Solder Splice
[url=https://flic.kr/p/WtbiyZ]
Crimped & Soldered Pins (Optional - Unless crimps are questionable)
[url=https://flic.kr/p/Wgzivp]
Old 12-29-2015, 03:30 AM   #14 (permalink)
Mpgrimm2's Avatar
Default
More Mpgrimm2 Extended Harness "Braided Sleeving" notes:
NOTE: I used braided nylon sleeving and heatshrink which can be a bit more difficult to work with vs split wire loom.
(i.e. I covered harness with 1/2' nylon sleeve/braiding. Finished with 3/4" & 1/2" heatshrink.)
[url=https://flic.kr/p/WtbhFB]
[url=https://flic.kr/p/VeCR7X]
[url=https://flic.kr/p/WtbgkF]
[url=https://flic.kr/p/WddAcS]
[url=https://flic.kr/p/WpBDY1]
[url=https://flic.kr/p/Wddzp9]
Other End 1:
[url=https://flic.kr/p/WpBCyh]
Other End 2:
[url=https://flic.kr/p/WddyzU]
Other End 3:
[url=https://flic.kr/p/WpBBs9]
Other End 4:
[url=https://flic.kr/p/VSWeYj]
Other End 5:
[url=https://flic.kr/p/WgzjPg]
Finished Harness w/Sleeving:
[url=https://flic.kr/p/WtbkZa]
R.L.K. and 69mach1 like this.
Old 12-29-2015, 04:59 AM   #15 (permalink)
1500ram12's Avatar
Ram Year: 2015
Engine: 6.4L Hemi
Default
DIY 5.0 to 8.4 Navigation upgrade
__________________
2015 Ram 2500 6.4L Hemi Tradesman, 275/70/18 Fierce Attitude MT, 18x9 ?, LED Interior Lights, 7" Premiun Instrument Cluster Upgrade, 2013 OEM Projectors, OEM Bumper w/fogs. Plastidip'd bumpers, Western In channel Vent Visors. Alpine INE-Z928HD HU, RF 200s amp, 2 10" MTX subs
1500ram12 is offline   Reply With Quote
Old 12-29-2015, 12:52 PM   #16 (permalink)
Mpgrimm2's Avatar
Default
Just a quick note on the bezel ...
There are 2 bezels that will work with the 8.4AN conversion...
- Preferred option 1:
SINGLE ZONE OEM 8.4" (MTC) BEZEL
P/N: 5VD75JXPAA or 1UJ96DX9AC (or AE, AF, etc)
- Workable option 2:
DUAL ZONE OEM 8.4" (ATC) BEZEL
P/N: _____________ or 1UJ97DX9AC (or AE, AF, etc)
The ATC bezel has all the same controls/buttons but also has 3 extra buttons that will be non-functional with the conversion.
The 2 right side buttons (up/dwn) for the passenger side Temp control (dual zone), and 1 (1/2) button on the center knob for the Auto temperature feature.
The ATC bezel was verified to work minus the items noted above by Cptwing, Jared4.7, See Here, (and later by Mpgrimm2).
Old 12-29-2015, 12:55 PM   #17 (permalink)
1500ram12's Avatar
Ram Year: 2015
Engine: 6.4L Hemi
Default
What post are you looking for exactly
__________________
Old 12-29-2015, 01:06 PM   #18 (permalink)
1500ram12's Avatar
Ram Year: 2015
Engine: 6.4L Hemi
Default
[quote name="Indaram" post=1007604]Here are the details for converting a 2014 RA2 MTC bezel "with 7 speed blower" to a RA3/4 MTC bezel for an 8.4 Uconnect Radio.
Parts Required For MOD:
8.4 Uconnect Radio (VP3/RA3 - Non-Nav) or (VP4/RA4 - Nav) **Check car-part.com or ebay.
Heater Control Module: - 68183973AB
Dash Controls: - 1UJ96DX9AF
Connectors & Pins to Make Adapter Harness (Required) (Use attached wire diagram and pinout below)
24 Pin Connector 1: 1318917-1 TE Connectivity | Mouser
24 Pin Connector 1 - Pins: 1123343-1 TE Connectivity / AMP | Mouser
24 Pin Connector 2: 1376103-1 TE Connectivity | Mouser
24 Pin Connector 2 - Pins: 1376109-1 TE Connectivity / AMP | Mouser
08 Pin Female - Connector: 30700-1081 Molex | Mouser
08 Pin Female - Pins: 1393366-1 TE Connectivity / AMP | Mouser
22 or 24 AWG stranded wire
Crimp tool to crimp the pins on the wire. (Check Amazon & Ebay for wire and crimp tool)
Harness Pinout
24 Pin Connecter (2014)
Pin 01 to Pin 01 (Also needs to splice over to Pin 4 on 8 Pin Connector)
Pin 02 to Pin 02
Pin 03 to Pin 06
Pin 04 to Pin 05
Pin 05 to Pin 04
Pin 06 Blank
Pin 07 to Pin 13
Pin 08 on Moves to Pin 2 on 8 Pin Connector
Pin 09 to Pin 07
Pin 10 to Pin 08
Pin 11 Blank
Pin 12 to Pin 10
Pin 13 to Pin 9
Pin 14 to Pin 14 (Also needs to splice over to Pin 3 on 8 Pin Connector)
Pin 15 to Pin 15
Pin 16 to Pin 16
Pin 17 to Pin 17
Pin 18 to Pin 18
Pin 19 to Pin 19
Pin 20 to Pin 20
Pin 21 to Pin 21
Pin 22 to Pin 22
Pin 23 to Pin 23 (Also needs to splice over to Pin 5 on 8 Pin Connector)
Pin 24 to Pin 24 (Also needs to splice over to Pin 1 on 8 Pin Connector)
Optional parts, See Note 1 below.
911/Assist Mirror: - 68096091AF
Antenna Cable Body Cell & SDARS "QUAD/CREW": - 68148279AD
Antenna Jumper Cable: - 68148258AD
Shark Fin Antenna: - 5091278AC
SD Card Media Hub: - 68096428AD
NOTE 1:
You can omit the Mirror, Antenna body cable, Antenna jumper cable, and shark fin antenna if you buy the OEM auto parts plug shown here:
911 Vehicle Phone Override Cable
Or you can make your own using the following parts (search ebay and amazon for these)
Farka D connector with 2 to 6 inch lead
10k Ohm Resistor with 5% tolerance, 1/2 watt.
Just solder one end of the resistor to the center wire and the other end to the wire shielding. Tape it up with electrical tape or heat shrink it.
NOTE 2:
There is a confirmed working mod for those that have a 2013/14 with 5 speed blower, but being I do not have that and cant confirm how its setup, I will not include those instructions in this post.
I take NO credit for any of this, just wanted to sum this info up for everyone here. All credit goes to getupkid and others for getting this project started and all their research. Please do not PM me asking me to make and sell you a harness.. I only made 2 and used them both.
********[/QUOTE]
R.L.K. and Mpgrimm2 like this.
__________________
Old 12-29-2015, 01:15 PM   #19 (permalink)
Mpgrimm2's Avatar
Default
Alright. 3.5hrs digging through cached webpages and I'm burnt out.
- Managed to get most of the Cptwing's Info on the conversion for 4 speed fan folks
(But no pictures)
- Absolutely could not locate a cached page of Indaram's Original post for the 7 Speed fan folks.
That original thread is locked and the relevant posts are missing.
- The 4 speed fan instructions by Cptwing at posts 81, 85, 88, 89, & 90 are lost along with the detailed pictures he posted.
I managed to dig them out from Google's cached web pages archive, but without the pictures.
-Indaram's original post 1 from his consolidated info thread detailing the 7 speed conversion was lost (part numbers, links, etc) and the entirety of his thread are gone.
I was able to go through the cached Google pages for relevant posts, but couldn't locate a cached page for Indaram's post 1.
EDIT: Thanks 1500ram12 for the above post!
R.L.K. likes this.
Old 12-29-2015, 01:28 PM   #20 (permalink)
1500ram12's Avatar
Ram Year: 2015
Engine: 6.4L Hemi
Default
Found this. I don't have time to go through it but might have what you're looking for
http://boardreader.com/thread/DIY_5_...pthuX1dtg.html
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
DIY: 2013-2014 8.4 Radio Upgrade cgeorgemo 4th Gen DIY 112 05-03-2016 11:50 PM
Steering radio control conversion? 1999CUMMINS General Discussion 0 12-04-2015 12:06 AM
8.4 radio conversion 911 Error Fix Plug Hootbro For Sale 1 09-27-2015 07:37 PM
help on radio upgrade BigDaddyRam Audio & Electronics 3 08-14-2015 04:27 PM
RBZ Radio upgrade JohnnyDollar Audio & Electronics 0 09-26-2013 07:18 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
