Eraser Wheel
daveray9
So, used one of these. Removed all of the double sided tape really well.
I bought the 3m one from Napa.. and yes paid about 25 more than I would have on amazon.
To whoever recommended goof off... ya, do NOT use that. FU*Ks up your paint.
Anyway... now that all the RAM 1500 is gone.. only thing that is left is the outline... but I'm not sure its from the double sided tape. I think its because the area of the paint under the emblems is still brand new.. and the paint around the outside is 4 years old.
Anyone got any secrets to remove that outline? Just wash and wax? Because I tried that but did a quick wax... maybe have to go a little bit more in depth.
Thx guys.
And anyone thinking about the eraser wheel... works awesome.
Ronan
I used gasoline for the double sided tape residue, truck was only about a year old though. Didn't mess up my paint at all. Worked like a charm
grozier
Independence mo
How about getting it off the door guards? I've been using goof off and that other crap that I can't think of the name
2015 ram sport 4x4
9th
Tallahassee, Florida
That's what happened when I remove the old sticker from my car.
Clean the affected parts by washing it and wipe it dry.
Rubbing Compound>Polishing Compound>Finish with Wax
Be careful with the Rubbing Compound, :)
You may first try Polishing Compound then Wax
tojo
3M eraser wheel is too damn easy not to use. Just make sure you keep it moving.
Sent from my SM-G920P using Tapatalk
Gearhead87
6.7l Cummins
Thx guys.
You should be able to use a light compound hand buff a few times polish and then wax. Or use a buffer if you have one available.
If the ghost image is still there you will need to do a light wet sanding with 1200 or above sand paper or block then do the steps above.
Hope this helps.
daveray9
daveray9
Hope this helps.
Thx man.
Gunna give it a go this weekend!
Gearhead87
6.7l Cummins
No problem! Post some pics of the results.
Glowrdr
Minneapolis, MN
Really been thinking about debadging my 2500. I usually do for all of my vehicles - I like the clean look, and makes it a ton easier to wash.
Part of me wants to keep the badges though, since its a Laramie with the 6.4 Hemi. I don't want a million questions about whether is a Cummins, is that the 5.7, is that the Big Horn, etc (I work for Cummins, so people just assume it would be diesel)
daveray9
daveray9
So leave just that emblem. I plan on putting the HEMI 5.7 one on.. just the blacked out one with the red. I hate chrome.
I actually think they look better with 1 emblem on the side. Rather than all the RAM 2500 / 1500 etc..
I will post some photos this weekend when I am done.
Metalizer
Pearland
Eraser wheel and regular ol gas has never failed me on badge removal....The rest of the stuff is a joke
Sent from my SAMSUNG-SM-G891A using Tapatalk
daveray9
daveray9
Eraser wheel is amazing.
