Front Drive shaft grease zert - where is it
bartbill
diesel
2015 Ram 2500 diesel. 16K.
The maintenance section of the owners manual says to grease this with every oil change with type 6560 lithium grease. It suggests it is a grease zert. I could use some help. I cant find it
RubberFrog
I just saw a thread about this the other day. It's inside the joint and it is a female fitting, so you will need a needle adapter. It's not the traditional baby *****.
am3334
