4th Gen DIY How to get your headlights out!
This is a discussion on How to get your headlights out! within the 4th Gen DIY forums, part of the Tech Info category! Register to remove these ads. It's free!
bmbrnsnrbrd wrote this up - I'm swiping it for RF!
First of all, ...
04-20-2011, 10:04 PM
#1 (permalink)
Site Administrator
Ram Year: 2010 1500 Crew
Engine: 5.7L
First of all, pop the hood and remove the insulator thing that runs across the top of the radiator, it uses six of the plastic push pin things:
One in each fender, two near the front (grill) area, and two large ones at the back of radiator:
What I do is pull up the five on the right, leaving just the one on the passenger side fender and rotate the insulator thing so that it sits on top of the engine:
Now, you have to remove the grill assembly. The grill uses four 10mm bolts along the top of the radiator support, remove these:
**NOTE: The outer two and inner two bolts are different. The outer two have threads spaced out much further since they bolt into plastic. The inner two have very close threads (and are shorter) since they bolt into metal.**
Once you have the four bolts removed, the hard part of removing the grill is next. You have to pull the grill straight out. On both sides, at the bottom of the grill (where it meets the bumper) there is a tab and insert. You have to gently, but firmly, pull on the grill straight out. Be careful as you WILL damage your paint/chrome. Here are the tab inserts:
Now, like the 3rd gen Rams, each headlight has two bolts (10mm) on the inboard side of the headlight. These are hidden by the grill. Remove them:
Next, the biggest improvement over the 3rd gen Rams is that there is no third bolt to try and access without damaging your front bumper's paint. But you do have to release the back of the headlight in order to remove it. If you look inside each front fender well (easiest to turn the front wheels fully one direction or the other) you will see a small access cover held in place by another small plastic push pin:
If you reach inside, there is a tab you have to push up to release the back of the headlight. It's a pain to find the first time, but if you use your flash light and look, it's very obvious. Push this up and then simply pull the headlight assembly forward.
The end!
__________________
RamForum.com Administrator / Preferred Vendor
RetroShop.us - Custom Automotive Lighting Specialists / Fukken Wax - the BEST waterless wash & wax on the planet!
☼ the Bitch ☼
2010 Ram 1500 Crew - Silver
Hemi / 4x4 / Sunroof / Bucket Seats / Alpine Surround Sound / Adjustable Pedals / Mopar T-Handle Shifter
20" Black XD Hoss Wheels / 295/60/20 Nitto Trail Grapplers / HBS 2" Level Kit / RCX 1.25" Body Lift / Bestop PowerBoards
SC Vivid / Volant CAI / TYC v6 eFan / Raceland Cutout / Bakflip G2 / Bed Mat / Stubby Antenna
Custom Painted and Retro'd BiXenon Headlights & Fogs / LED Tails / Debadged & Custom Front & Rear Badges / Mufflex 5" Exhaust Tips / Viper 5701
Kenwood DDX319 / Fiberglass 10" Sub Box / Kicker 1000.5 / Kicker 10" CVX
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
04-20-2011, 10:08 PM
#2 (permalink)
Ram Year: 2006
Engine: Hemi 5.7
Holy hell, that looks like a pain in the ass. Good write up JJ!
__________________
Regular Cab Crew Join
Blue Truck Club Join
bilstein 5100 level(sorta) matching 5100's in back OL delete to level completely magnaflow y to si/do cherry bomb extreme 45'd out the back SC 3865 91 tune little tq adjustment for now 4" home brew cai power wire efan plastidip on the front grill custom blue led's behind the emblem Rubberfrog Tactical Grill
04-20-2011, 10:20 PM
#3 (permalink)
Site Administrator
Engine: 5.7L
oh, its stupid as hell........LOL
And you have to do all of that to CHANGE A BULB TOO!
All credit goes to David! He did the write up a few months ago, thanks David!
__________________
☼ the Bitch ☼
04-20-2011, 10:22 PM
#4 (permalink)
Ram Year: 2006
Engine: Hemi 5.7
Wow.... screw that lol. I'll stick to third gen then lol
__________________
04-21-2011, 04:43 AM
#5 (permalink)
Ram Year: 2010
Engine: 5.7 Hemi
That is freekin insane!! Why would dodge do this settup?That is crazy.
__________________
2010 Ram 1500 HEMI
6" BDS Lift 4th Gen 1500 8"+ lift Club #1
Bilstein 5100's set at max 2.8" total of 8" Lift 37x12.50x20 Black Truck Club #36
04-21-2011, 11:13 AM
#6 (permalink)
Site Administrator
Engine: 5.7L
Honestly........no clue. I don't get it at all!
__________________
☼ the Bitch ☼
06-18-2011, 10:58 AM
#7 (permalink)
Ram Year: 2011 Power Wagon
Engine: Hemi 5.7
ya its pretty crazy but its not bad after you do it a couple of times
__________________
  2011 Dodge Power Wagon 5.7 Hemi Inferno Red/Black two tone - Lockpick, 12,500lbs Warn Winch, Bilstine Shocks, Lockers Fnt/Rear, Cb Radio, Wireless Warn Remote, Bushwackers, Super swamper M-16 40x14.5x20, 20" BMF Novekane Rims, Zone 2.5" level kit, HBS Steering Stabilizer, Custom Top Gun 8" lift kit
07-13-2011, 03:12 PM
#8 (permalink)
Ram Year: 2009
Engine: 4.7 V8
nice write up, ill be using it this weekend
__________________
2009 Dodge RAM SLT 1500 4x4 - Flowmaster 40, K&N drop in, Mopar Chrome Grille, Mopar Clearance Lights, Mopar Tow Package, Bilstein Struts Maxed @ 2.8'', RCX 1.25" BL + .75'' Rear Spacer(4'' of lift and level!), Dick Cepek DC-2 wrapped in 33'' Nitto Terra Grapplers, bed lined fender wells, 2.5% tint
07-13-2011, 04:40 PM
#9 (permalink)
Ram Year: 2011
Engine: Hemi 5.7
I'll throw my 2 cents in about the slight issue I had.
My fat kid hands were too big to really easily find the 'hidden' super secret tab on the inside. So I used the camera on my phone to find it in the small hole. Once I knew were it was presto easy out. Also, the light housing is ball socketed in and takes a good bit of force to release it.
07-13-2011, 05:15 PM
#10 (permalink)
Ram Year: 2011 R/T
Engine: hemi 5.7
u dont need to remove the grill just get a long ext with a deep 10mm and put some duct tape in the socket and boom 5 mins the light is out i have a 2011 and have had my lights out 5 times and not once removed the grill
__________________
MODS-Spyder headlights, 10k hid's low and fogs,2'' ground force drop,magnaflow,custom painted interior and engine bay,tinted tails,3rd brake light,puddles and windows,bedrug,flip back cover,debadged,billet accessories,more sexiness to come-custom stereo,cam headers and programmer(when they make one )srt hood and supercharger,new rims
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
