Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Tech Info > 4th Gen DIY
Sponsored Ads
Register to remove these ads.
4th Gen DIY
How to Install coil spring lowering kit (Ground Force)
This is a discussion on How to Install coil spring lowering kit (Ground Force) within the 4th Gen DIY forums, part of the Tech Info category!
Register to remove these ads. It's free! Ok dudes, This guide is for any coil spring drop (front and rear) ...
Reply
Old 12-10-2011, 05:26 PM   #1 (permalink)
Trupiano's Avatar
4th Gen / Site Mod
Location: Hometown : Puyallup,WA Stationed : Little Rock, AR
Name: Steven [TRIP/TRUP]
Ram Year: 2011 Ram 1500 4x4 Hemi Crew Cab Sport
Engine: 5.7L HEMI
Talking How to Install coil spring lowering kit (Ground Force)
Ok dudes,
This guide is for any coil spring drop (front and rear) and install of rear shocks. This drop kit was Ground Force's 2/3 inch lowering kit, Drop Part # 9984 for 2009-2011 Hemi Quad cab/Crew cabs. Lets begin...
Took me 6 hours to complete this at the base hobby shop with all the tools I would need... and that was with taking all the pictures for this guide, and having no help. I did this 100% on my own. (I don't recommend that)
Here's the Ground Force drop instructions page for page, just in case you need them. (Will upload later)
1. Start by measuring each corner of the truck from the top of the tire, to the top of the fender. Record this. Mine was 4" in the front and 7 1/8th" in the rear.
2. Jack the truck by the frame. Make sure it's securely on there. You don't want your drop to look like this.
3. Try to keep the lift only approx 4-6 inches off the ground to help with removal/installation.
Rear Removal/Installation
4. Place a floor jack under the rear axle(differential) for support. You'll need this a little later on.
5. Remove the rear tires, then the wheel well liners. You'll need them removed for the next step... TRUST ME! It's only 8-10 small bolts, then just pull like hell and it'll come out.
6. Remove the rear shocks. I believe this was a 19mm socket. The lower shock mount bolt was easy to remove, while the upper was hard as hell. The upper inner nut is almost impossible to get out without "Shady Maintenance". The shock mount is recessed in making it impossible to get a socket squarely onto the nut, and the bed rails leave almost no room for a wrench or ratchet. I used a small wratched with the socket and just smashed it onto the top part of the nut, then used an air impact gun on the bolt head. The nut will spin inside the socket a lil, cause you can't get the socket onto it squarely... but put enough pressure and it'll come off.
7. Disconnect the rear anti-lock brake sensor line plastic clip from the brake assembly so it wont be in the way. Don't over extend the brake lines, or this wire or you'll be sorry. So watch it when your lowering the truck later to remove the coils, cause it'll get close!
8. Remove the lower sway bar connecting hardware from the sway bar end link, and also it's mount, then set the them aside.
9. Now, carefully lower the floor jack under the rear differential till your coils either fall out, or you have enough room to pull them out. BE CAREFUL TO WATCH YOUR BRAKE LINES/WIRES ON BOTH SIDES WHEN LOWERING THE FLOOR JACK, AS THEY WILL HANG, AND COULD POSSIBLY RIP OUT!
10. Save the rubber pads and the insulators that were on top of your coil springs. Look how were installed, so you can reinstall them the same way on your new coils.
11. Replace the bump stops. This is easy, no explanation necessary.
12. If your kit came with coil sleeves, install them on the the new rear coils starting at the top. (end of the coil with top wraps/ Ground force logo will face up) They will only cover half the coil spring. These help with any noise or squeeks once the coils have the trucks weight on them.
13. Put the stock rubber pad/insulater onto the new coils. Make sure they the top coil ends are lined up perfectly with the insulator pad, just like they were with the original springs. Should be an impression from the old coils.
14. Put the coils onto the lower sprin seat, twist them a lil to get them to seat if needed, and ensure the upper insulator pad is still seated properly.
15. Carefully jack up the axle with the floor jack to seat the springs, stopping after every couple inches to check the seating.
16. Install the new shocks, same as the old ones were removed.
17. DRILLING PART! New sway bar mount needs to be drilled. Measure and mark with a punch 13/16" in from the rear, and 1 5/8th" from the top. Then drill a 1/2" hole for on both sides of the truck for the sway bars to mount to.
18. Mount the sway bar end links with the new spacer supplied, on the outside of the new mount hole. Then install the lower sway bar end link onto the sway bar, but this time connect the bushing from the outside, vs. the inside like it was originally installed.
(PIC LATER)
19. Look over everything you've touched, and make sure they're torque down "good'n'tight", and everything is installed correctly.
20. Install the rear wheel well liners, and wheels.
21. Lower the floor jack and remove from the area.
See next post for Front Install!
__________________
RamForum.com Moderator
Exterior: Black Grill l Debadged l Tint l Fukken Lights 5K H/F l Stubby Antenna l Custom Painted Mopar Stripes l Tinted Tails l Access Tonneau l G/F 2/3 Drop l 22' boss 330
Interior: Radar Blendmount/Hardwire l TomTom Hardwire l WeatherTech Mats l Lockpic l B/U Camera
Performance: 14' Magnaflow l Res Delete l Sonnax Line Booster l BT CatchCan l Volant l 306HP/331TQ DYNO VIDEO
Trupiano is offline   Reply With Quote
Old 12-10-2011, 05:27 PM   #2 (permalink)
Trupiano's Avatar
4th Gen / Site Mod
Engine: 5.7L HEMI
Default
Front Removal/Installation
Continuing from step 3 on the previous post...
4. Remove the front tires.
5. Support the lower control arm with a floor jack or jack stand.
6. Remove the sway bar connecting nut/bushing from the sway bar, and disconnect the end link.
7. Remove the tie rod hardware/bushing and disconnect. Some PB Blaster and a rubber mallet should work wonderfully!
8. Remove the upper ball joint hardware/bushing, and disconnect. Same way as above, PB Blaster and rubber mallet. Ensure you attach the upper part of the spindle to a point on the truck with either a zip tie, hangar, or safety wire. Keeping it from hanging on the brake lines is very important!
9. Remove the anti-lock brake sensor wire clip from the spindle.
10. Loosen and remove the lower strut mounting bolt. If the bolt is stuck, use a rubber mallet and some PB Blaster, and wiggle or shake the spindle to aid in the removal.
11. Remove the 3 upper nuts attaching the strut to the frame. Then remove the strut assembly.
12. Using a coil spring separator, remove the OEM coil spring, and reinstall the new drop spring. Ensure the drop coil spring is installed correctly, (ground force logo up) and the upper strut rubber isolator and spring seat are properly installed and seated.
13. Reinstall onto the truck the same way it was removed, and torque the 3 upper nuts and lower mount bolt TIGHT! IMPORTANT: If the upper 3 threads aren't aligned with the lower strut mount, place the lower part of the strut in a vice, and using a pry bar or large screw driver through 2 of the 3 threaded studs, rotate the upper part of the strut till it is aligned with the lower mount. Then remove from the vice and install back onto the truck.
14. Reinstall the upper ball joint hardware and torque.
15. Reinstall the outer tie rod hardware and torque 55 ft. lbs.
16. Reinstall the sway bar connecting links to the sway bar and torque 27 ft. lbs.
17. Reinstall the brake line clip back onto the spindle.
18. Check over everything you touched and ensure they are attached and torque properly.
19. Reinstall the wheel/tire and torque.
20. Down jack the truck.
21. Measure your new clearances. Mine was 4" in the rear, and 4" in the front almost dead even!
22. Start the truck, and turn the wheel from right stop to left stop and check clearances.
23. Road test the vehicle. Take it over some speed bumps, check the steering responsiveness.
24. Take the truck and get it aligned. Prolly a good idea to recheck the nuts and bolts you tightened after the alignement, and retorque them.
24. Done-sky!
__________________
Old 12-10-2011, 05:33 PM   #3 (permalink)
EJM05's Avatar
Ram Year: 2010
Engine: Hemi 5.7
Default
MAke sure you sticky this!!! Awesome write up so far!
__________________
Dodge Ram Forum | Ram Forum | Ram 1500 Forum | Dodge Truck Forum | Dodge Ram Parts | Dodge Ram Accessories | Dodge Ram Performance
EJM05 is offline   Reply With Quote
Old 12-10-2011, 05:37 PM   #4 (permalink)
Trupiano's Avatar
4th Gen / Site Mod
Engine: 5.7L HEMI
Default
Still need to take a couple pics I missed, and edit some of the pics with paint. But thanks!
__________________
Old 12-10-2011, 07:03 PM   #5 (permalink)
iSlacker816's Avatar
Ram Year: 2001
Engine: 5.9 (360ci) Magnum
Default
Pic of final product????
__________________
2001 5.9 Magnum 195,xxx Miles - 32" Hankook Dynapro ATM's - Glasspack - Dash Cap - Tinted Tail and 3rd Brake Light - Spectre CAI - HBS 2" Level - HBS Steering Stabilizer - Superchips Flaspaq 3865 - Husky Molded Floormats - Hughes Engine's Plenum Kit - 8 Pass Transmission Cooler - 4 Off Road Lights Behind The Grill w/ Custom Made Light Bar
iSlacker816 is offline   Reply With Quote
Old 12-10-2011, 07:27 PM   #6 (permalink)
City Slicker's Avatar
Ram Year: 2007
Engine: 4.7L V8
Default
http://www.ramforum.com/220318-post64.html
City Slicker is offline   Reply With Quote
Old 12-10-2011, 08:13 PM   #7 (permalink)
jojo750's Avatar
Ram Year: 1963
Engine: 2.0
Default
good stuff.
i used a stubby wrench to get that top shock nut off.
fit perfectly in that space.
thanks for the pics. its one thing i couldnt do while installing my kit.
__________________
mcgaughy/belltech/vararam
jojo750 is offline   Reply With Quote
Old 12-10-2011, 09:56 PM   #8 (permalink)
DisturbedGator's Avatar
Ram Year: 2011
Engine: Hemi 5.7
Default
do they have a full service shop on LRAFB? i know they had one on eglin when in was there. also good right up
__________________
DisturbedGator is offline   Reply With Quote
Old 12-10-2011, 09:59 PM   #9 (permalink)
Trupiano's Avatar
4th Gen / Site Mod
Engine: 5.7L HEMI
Default
Hell yeah man! They had every tool I could ever need.
__________________
Old 12-10-2011, 10:02 PM   #10 (permalink)
05singlecabHEMI's Avatar
Ram Year: 2005
Engine: 5.7 HEMI
Send a message via Yahoo to 05singlecabHEMI
Default
Great write up. You always make good write ups lol
__________________
night vision HID kit, Pacesetter LT headers dual exhaust flow master 40series dumped before the axle, vararam air intake, 1.5inch leveling kit, Dakota AT^2 tires, plastidipped wheels. raceland 3" cutout, SC 3865 tuned, rocket wire, aeroforce gauge in a SRT 10 pillar with A/F ratio, color matched gill, plasti dipped bumpers.
05singlecabHEMI is offline   Reply With Quote
Reply
Bookmarks
Tags
4x4 lowering kit install, ground force kit, how to install drop kit
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ground Force Drop #9984 Trupiano 3rd Strike Performance 23 12-10-2011 04:01 PM
G force Performance Chip Kit Rampower Engine & Performance 6 09-07-2011 11:26 AM
1977 to 1992 Coil Spring? rodeofan5656 1st Gen : 1981 - 1993 3 05-11-2011 01:23 PM
Please help, dealing with coil spring struts sullivan General Discussions 19 03-17-2011 03:32 PM
force unleashed 2 truckin151 Gaming 4 11-02-2010 12:58 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
