4th Gen DIY How to mount lights behind the grill with no brackets
This is a discussion on How to mount lights behind the grill with no brackets within the 4th Gen DIY forums, part of the Tech Info category! Register to remove these ads. It's free!
Now that I took off my bullbar, I wanted to do something with ...
11-19-2011, 06:29 PM
#1 (permalink)
Ram Year: 2009
Engine: 5.7L Hemi
Now that I took off my bullbar, I wanted to do something with my KC lights. They're 130W Stainless 6" Daylighters. I did not use any brackets. There may be other ways of doing this but this was the easiest way for me to mount my sized lights.
I measured across the metal support rail in front of the radiator and drilled holes to fit the 1/2" mounting bolt on the bottom of the KCs. I measured 6" on the drivers and 5-7/8" on the passenger side. The reason the measurements are different is I kept setting the lights where I thought they should be, put my grill back on, and measured from the center of the grill openings. I drilled about 1/2" in front of the metal rib running across the center like in the pictures.
Once drilled, I deburred and painted the bare metal with some black paint. Then mounted the lights using a large washer to hold the light in place. If you look in the pics, there is not alot of room to tighten the nuts underneath so you need to use an angled rachet wrench, not much else will fit under there. The passenger side is by far the hardest to tighten up.
Then I ran my wires to the lights and they worked! There is clearance between the radiator and the back of the lights and about 1/2" or more between the lenses and back of the grill. I'm going to keep an eye on them for a little while and make sure they are not rubbing anywhere else.
__________________
2009 Dodge Ram 1500 4x4 Hemi Big Horn
-6" BDS lift, Bilstein 5100s @ 2.1", Kumho 37x13.50-20, Eagle Alloy 079 20x9, AEM Brute Force CAI, 18" Mufflex, Predator tuner, PW flares, TRX grill, G2 Bakflip, KCs behind grill, 5K HIDS, Recon White Lightning bar & 3rd Brakelight, Painted Heads, Tinted Fogs & Tails
11-19-2011, 06:30 PM
#2 (permalink)
Ram Year: 2010
Engine: 5.7 Hemi
Nice read Brad!! Thanks bud!! Got any pics of it done???
__________________
2010 Ram 1500 HEMI
6" BDS Lift 4th Gen 1500 8"+ lift Club #1
Bilstein 5100's set at max 2.8" total of 8" Lift 37x12.50x20 Black Truck Club #36
11-19-2011, 06:31 PM
#3 (permalink)
Ram Year: 2009
Engine: 5.7L Hemi
Continued...
__________________
11-19-2011, 06:32 PM
#4 (permalink)
4th Gen / Site Mod
Ram Year: 2011 1500 Sport Quad Cab 4x4
Engine: Hemi 5.7
very nice.
__________________
RamForum.com Moderator
11-19-2011, 06:34 PM
#5 (permalink)
Ram Year: 2009
Engine: 5.7L Hemi
Night shots!
__________________
11-19-2011, 06:40 PM
#6 (permalink)
Ram Year: 2010
Engine: Hemi 5.7
Awesome! I still need to mount my lights behind the grille. Awesome write up!
__________________
Dodge Ram Forum | Ram Forum | Ram 1500 Forum | Dodge Truck Forum | Dodge Ram Parts | Dodge Ram Accessories | Dodge Ram Performance
11-19-2011, 06:55 PM
#7 (permalink)
Ram Year: 2009
Engine: 5.7L Hemi
Thanks! It would have been alot quicker if I didn't make 2 trips to AutoZone....which meant re-bolting my grill back on each time, then off, then on, etc...I'm sure all lights are different but the only hard part was tightening those nuts, esp the pass side
__________________
11-19-2011, 06:57 PM
#8 (permalink)
Ram Year: 2010
Engine: Hemi 5.7
Where did you put your switch? Got any pics?
__________________
11-19-2011, 07:22 PM
#9 (permalink)
Site Administrator
Ram Year: 2010 1500 Crew
Engine: 5.7L
very nice!
__________________
RamForum.com Administrator / Preferred Vendor
RetroShop.us - Custom Automotive Lighting Specialists / Fukken Wax - the BEST waterless wash & wax on the planet!
☼ the Bitch ☼
2010 Ram 1500 Crew - Silver
Hemi / 4x4 / Sunroof / Bucket Seats / Alpine Surround Sound / Adjustable Pedals / Mopar T-Handle Shifter
20" Black XD Hoss Wheels / 295/60/20 Nitto Trail Grapplers / HBS 2" Level Kit / RCX 1.25" Body Lift / Bestop PowerBoards
SC Vivid / Volant CAI / TYC v6 eFan / Raceland Cutout / Bakflip G2 / Bed Mat / Stubby Antenna
Custom Painted and Retro'd BiXenon Headlights & Fogs / LED Tails / Debadged & Custom Front & Rear Badges / Mufflex 5" Exhaust Tips / Viper 5701
Kenwood DDX319 / Fiberglass 10" Sub Box / Kicker 1000.5 / Kicker 10" CVX
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
11-19-2011, 07:30 PM
#10 (permalink)
Ram Year: 2009
Engine: 5.7L Hemi
My switch is mounted under my dash underneath the steering wheel. I'll snap a pic for you tomorrow
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
