09-17-2011, 07:53 AM
#1 (permalink)
Site Administrator
Ram Year: 2001 Off Road
Engine: 5.9L V8 Sport
How To Trailer Brake Install Factory
Register to remove these ads. It's free!
The controller P/N is: 56029431AF
The beige trim is: 1EB13DK2AA
Installation took 15 minutes after discounting the fact that I was taking pictures.
This is where the factory controller is mounted.
This is the new bezel.
Face of new controller.
Bottom of new controller.
Mount the controller into the bezel. There are 2 screws you'll need to dig up and they're both different sizes. Careful not to attempt to use a screw that's too big or you'll split the plastic casing.
Remove these two Philips screws and don't lose them.
After the screws are out, carefully pull the panel straight back. The ODBC connector and hood release can be left attached.
Once the center panel has been removed, the first of two mounting screws for the cubby are exposed. It a Torx screw.
On the left side of the dash panel is a small access door. It pulls out from the leading edge. Be careful not to just jam a screwdriver in there and pry it open or you'll mark up the sharp edge of the dashpad. I inserted a small screwdriver just enough to get my fingernail in and pull it out. Take it easy here because you can see any marks you make. Plastic trim tools would work well here also.
Now that the access door is open the second retaining screw for the bezel is exposed. Remove both screws now and pull the cubby straight out of the dash.
Up under the left side of the dash (fairly close to where you're working) you should find two grey connectors that are taped to the harness. Untape them and route them to the opening you'll be inserting the new bezel and controller into.
Carefully insert the controller and bezel assembly into the opening and press it firmly into place so the secondary clips on the bezel seat properly into the dash. Plug in the connectors you untied above (they are two different sizes so you won't mix them up) and reinstall the two Torx retaining screws. Turn the ignition on to ensure that all the LEDs illuminate then go off. If it functions correctly then close the left access panel, replace the lower trim and secure it with the original screws.
This is the finished product with protective film removed from controller face.
__________________
RamForum.com Administrator
Superchips 3715;3rd gen 20s; Cat back exhaust, no muffler;Custom Grill Insert; SRT Hood; Hummer Nerf Bars (PD);Roll Bar (PD); Halo Projectors w/ 6K HIDs; Tow Mirrors; Body matched antennae base and handles; Custom tail Stripe; Custom decals; Painted frame, suspension parts, and wheel wells; Air Horn; Aluminum fuel door; one of kind dents and scratches; 2.5" TGC Leveling Kit; Bilstein 5100 Shocks; LED dash lights ;Cleared needles; blue switches; Painted dash pieces; Pioneer CD player; Cerwin Vega 6x9s , Alpine 5 1/4;Kenwood amp; Boss sub w/Boss Amp; 5% window tint on the back, and strip on the front;[/COLOR]
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
