krb686
- Dec 30, 2014
- 53
- 4
- 2014
- Hemi 5.7l
There are a number of things wrong with that service managers statement but I'm going to keep this simple.
The mileage of the truck is recorded and stored in the BCM.
The cluster is a read out device not the storage device.
The reason they would want to void a warranty is because someone could put a low mileage cluster in a high mileage car and then try to get warranty work done they don't qualify for. A simple scan of the BCM and the actual mileage is revealed.
I personally have had my truck repaired 3 times for minor things (door handle, leaking brake light, and airbag light) and they have all been covered under warranty with not a peep about the new cluster.
And if push comes to shove you go to an arbitrator and ask them to have the dealership scan the BCM find the mileage and move on with the warranty work. Just because they say no doesn't take away your right to arbitration.
The cluster is certainly not merely a read out device. If it were, there'd be no need to have clusters programmed at all, and it would be setup so we could just swap them out and they would display whatever mileage the truck sent them. I'm not saying that the truck doesn't have other modules that store the mileage in addition to the cluster, just saying the cluster certainly stores the mileage.
