So quick questions just purchased a 15 2500 6.4l and just read the whole thread. I'm assuming it doesn't matter whether the cluster came out of a 1500 or 2500 correct? wanting to do this mod
Are these still available? Definetly want one if so..If anyone needs 7" Clusters, I have 6) 7" Gas Clusters and 1) Limited 3.0L EcoDiesel 7" Cluster. $425/each shipped.
I used ICS, never had a problem.Getting set to have it programned.. any thought between using Nav2go or instrument cluster shop ?
Kept it hooked up over the weekend to be sure it works fully.. and it's so cool looking.. ready to get it adjusted as mentioned but interestingly nav in the display never worked. Did a couple of short drives and used navigation back home, it called out the turns, " in 1000 feet turn..." but display never changed from the speedometer I had currently selected to show. I will a factory reset of the RA4 later. Not a big deal, as I'm happy overall but wondering why it's acting as if not enabled. I have the 15 uconnect update. So no option to select this feature any longer that I'm aware of.Your Nav will come up in your display. It only comes on about a thousand feet or so before you are going to make a turn. Once you get going it will start working. Some of the units have an option to turn the navigating display in the cluster on and off. It is taken away in the later Firmware updates and is on automatically on all the time. Don't drive it to much untill you have it programed you want your mileage on your P.C.M and your cluster to match in case you ever have an issue with warranty or anything else. Looks nice! Your gonna love it.
