Ty for the color comment and Ty for these threads ..makes other people's jobs alot easierGreat job Sir !
Love the color of your Ram .
Depends on what you're after ?Should I go from .75 to 1.5 or just put airlift on it?
49k and I'm still on my factory shocks in.the back & I have 1.5" TGC rear coil spring spacers installed.What rear shocks are people using with the 1.5" spacers. I've been told factory are ok.
The factory ones are fine for the 1.5" spacers . I.see lots of folks running the bilsteins in the back .
I put jackstands on the frame just fwd of the axles , but you could put them anywhere near that location or more to the rear .@R.L.K. I stumbled on this thread doing research myself. Great write-up. I just had Fox 2.0 shocks added along with Bilstein 6112s up front on my Zone 6". I am tossing 37s on later, but until then I see I am 3/4 nose high and will put in a 1" TGC spacer. In looking at your DIY, you mention jacking at the diff then jackstands on the frame. Can you give me a suggestion of frame position for the jack stands? I have always just put jack stands on the axle in the rear.
Thanks!
Here's some pics I just screenshoted and zoomed in a bit from my OP .@R.L.K. I stumbled on this thread doing research myself. Great write-up. I just had Fox 2.0 shocks added along with Bilstein 6112s up front on my Zone 6". I am tossing 37s on later, but until then I see I am 3/4 nose high and will put in a 1" TGC spacer. In looking at your DIY, you mention jacking at the diff then jackstands on the frame. Can you give me a suggestion of frame position for the jack stands? I have always just put jack stands on the axle in the rear.
Thanks!
great job super good commentary, i appreciate your work for usThanks guys ! I DO Appreciate all the Kind words !
Thanks man , means a lot [emoji1303]great job super good commentary, i appreciate your work for us
