dooramit
- Oct 13, 2013
- 9
- 4
- 2010
- Cummins 6.7L
A friendly suggestion:
If you use the pigtail (Item #2 in the original post) that connects to the LED taillight plug, silicone the holes shut for the 2 empty terminals that aren't used.
If you hold the plug up to the light you can see right through the hole in the rubber insert on the backside of the plug. If any moisture/water gets in there its basically inside the entire connector.
