How to Add Automatic Temperature Control (ATC) to a Manual Temperature Control Truck
STecoD
NorCal
2015 Crew Cab Tradesman
3.0L Diesel
It being grayed out on the screen concerns me.
stimpy433
IOWA
supposedly I do but I've been baffled on how to turn them on/off. It didn't get frosty last winter to need them so I didn't spend time trying to figure them out.
#5 on both pictures turns on your heated mirrors....
Rut Row
3.0L Diesel
ah-HA! I just checked truck. It does have the buttons and they do work and the one on the display is lit.
Rut Row
3.0L Diesel
This is what I'm used to seeing. Both work.
https://youtu.be/yMT2zC25UHQ
I don't know how the auto mode is supposed to work, but when you click "auto" the AC lights go out. AC still works. When I click the other buttons they work. I'll do a video later to show that. Again - I'm assuming that is how it is supposed to work.
stimpy433
IOWA
If you watch the video that infotainment posted the AC light is on but then turns off when he switches to AUTO mode.... Maybe the light only comes on when the temp sensor indicates a need for the AC??? Need to verify with a OEM setup to verify I'd guess.
Or maybe it's off so that the damn thing isn't continuously blinking on/off all the time.....
Rut Row
3.0L Diesel
that is true, the AC lights turn off. However the AC continues to work. The fan changes as needed but the light stays off until you put it back in auto mode. It would be nice to see what the factory versions do, but I'll bet they are the same.
DeereGuy
DeereGuy
Pittsburgh, PA
It's my understanding that the AC lights completely go off when in auto mode on all trucks whether factory equipped or converted.
WilliamS
Tampa FL
Yes the AC light should be off. This is how all the trucks I have on my lot operate as well. The truck will determine the need for the a/c compressor based on temp requested. If you change the fan speed or take out of auto the light will illuminate. I have 4 laramies here on the lot 1500 and 2500 as well my fathers power wagon all operate this way.
walker111
So mine still shows 2 sliders. I shut it off/on a few times with 3-5 minutes in between a few times and still nothing. It was 104 degrees so I gave up til tomorrow.
Rut, your switch to single zone first try?
Rut Row
3.0L Diesel
it took me two tries for the second Genie. Be sure to wait 1-2 min after turning off the truck and opening the door after each flash
obdgenie
Hemi 6.1
If you cycle the car on and off 2x with 1-2 min in between it will work no need to do the genie again. Radio needs to be reset and sometimes takes 2x to get it to.
00R/T
CT
Correct. The A/C light doesn't indicate the compressor is running but rather that you manually requested A/C. You also won't have the front defrost light on even though it goes to defrost when you put it on auto in the winter.
walker111
Is there such a thing as waiting too long? I definitely waited more than two minutes earlier, and I just went out again after a couple of hours and it’s still in dual mode.
DeereGuy
DeereGuy
Pittsburgh, PA
No. The truck will just stay in the current state until the next flash.
walker111
So am I ok plugging the #2 genie in a second time to try again?
RedFlameRam
