skuppy069
- Feb 26, 2017
- 795
- 362
- canada alberta
- 2018 1500 cc
- hemi 5.7
I’m glad you guys got it all figured out .Good job .
OBD Genie simply jumped on the bandwagon when the mod was figured out by M2mods and others.Great work tracking the problem down.
I'm curious how OBD Genie didn't catch this problem? They make no mention of having to add a humidity sensor.
I debating selling my set up, I have the harness from M2Mods, temp sensor and the OBD Genie(nothing has been installed) or wait till M2 comes up with a harness for the humidity sensor.OBD Genie simply jumped on the bandwagon when the mod was figured out by M2mods and others.
Sent from my SCH-I545 using Tapatalk
I tested my system today under every possible parameter I could think of and it seems to function perfectly now. It is not hard hook up the humidity sensor and I'm sure whatever harness M2mods comes up with will be practical and easy to install. This is absolutely one of my favorite mods and you get spoiled to it really quick. You set your temperature where you want it and you forget about it. If you have remote start it automatically turns on your heater in the winter and your air conditioning in the summer. I mainly wanted to fix it because I can't stand when something doesn't function properly and I do like to run my vent sometimes in the springtime to save on wear and tear on the system. Highly recommend you keep your stuff and install the ATC mod I promise you won't regret it if you do.I debating selling my set up, I have the harness from M2Mods, temp sensor and the OBD Genie(nothing has been installed) or wait till M2 comes up with a harness for the humidity sensor.
The last time I checked the solar sensor faults were still present but sometimes it takes a while for them to go away. I will try to check again tomorrowJust out of curiosity do the solar sensor faults still exist ?
Lol it was definitely a group effort and a lot of behind-the-scenes communication back and forth. It just so happened that STecoD and I both had trucks that were affected so we could do the testing, that being said if I lived close enough I'd definitely take you up on it! Definitely do not hesitate to install it now. As I stated it works perfectly and it is extremely nice to have.If you were close enough I'd buy you a beer or two for all your testing and sharing the results. I'm the same way, I like things to work right, sort of why I was having second thoughts on installing.
I’m waiting on the harness as well and the bugs worked out with flashing the 8.4 to accept ATC! Only step I have done is I have the temperature sensor installed and ready.
Now that we have the alphaOBD set up if you wanted to purchase the app it works fine to install the correct codes for the ATC. All you do is set the Dual Zone ATC control and then go back out then go back in and set the single zone ATC control and you're done. Ghost-Ram I was able to set his with the tool with zero issues. Also as Mpgrimm2 stated since your truck is a 2013 and does not have the variable rate compressor you don't need to install the humidity sensor or any of that wiring.
