Hi All, I've read thru the forum posts a couple of times, and I'd like to ask a couple of questions if I may:
I just purchased a 2015 1500 Tradesman.. (4,000Km's away at the moment so physical access to check things is rather difficult)
I really want to do this MTC to Single Zone Automatic Temperature control.
#1 - The HVAC Module required, would that module already be in the vehicle? Or do I need to get/ swap it for a different one?
#2 - I'm a bit confused about the bezel. In places I see that one of the members is modifying the circuit board for single zone. I have a bezel with dual zone controls in it from a donor Laramie wreck. Are there circuit board modifications required? Or can I just use the dual zone control as is? (obviously the passenger side would not function, I think).
#3 - You guys show a single zone ATC set of buttons. Where did you get those ? Part Number or vehicle/model that has them. If I were to get a set of single zone buttons, would any circuit board modifications still be required?
Thanks very much, great thread by the way. I'm really looking for to doing this mod, along with an 8.4 Nav upgrade and heated/cooled/power set upgrade with heated steering wheel (gets too cold for me here in Canada these days... I'm just gettin' older I guess.
