OnSale
5th Gen Crew
- Nov 12, 2016
- 3,218
- 1,723
- Philadelphia, Pa
- 2020
- Hemi 5.7L
***** This write-up is a WORK IN PROGRESS and will be updated as the work is done. Video will be uploaded after the lights are finished, installed, the write up with pictures is done and then after I edit the video. Please be patient. I expect to be done this entire tutorial, video and all, within the next 14 days. Thank you for your patience. *****
Ok, so I am finally getting around to doing my custom 13+ Projectors and wanted to make a thread for the build so I can hopefully share my knowledge and experience with anyone else who wants to do this mod. I havnt seen a full in-depth guide yet with pictures and a video so I figured I would help out the community and make one.
I already have the lights, they are TYC Replicas, NOT OEM. So if you have OEM, everything will be the same except baking times and how hard they are to open.
What is being done:
• Custom Painted Flame Red & Black
• Tinted (smoked) Corner Reflector & Turn Signal Lense
• Diode Dynamics HD LED Projector & C-Bar Switchback Halos
• Diode Dynamics Lower Turn Signal/Running Lights Switchback LED Boards
Things needed:
• 13+ OEM or TYC Projector Housings
• Retroshop Adapter Harness (needed for 09-12 Rams and 13+ that came from the factory without oem projectors)
• Diode Dynamics 13+ Ram Projector/C-Bar Switchback HD LED Halo Kit
• Diode Dynamics 13+ Ram Turn Signal/Running Light HD LED Boards
• T10 Torx Bit or Driver (for headlight disassembly)
• 10mm Socket (to remove dust cap)
• Flat Head Screw Driver or Prying Plyers
• Fine-grit Sandpaper (if painting)
• Twist Ties (kind with small metal wire inside of the tie)
• Dremel or drill with small drill bit
• Epoxy or JB Weld or Silicone
• Morimoto Butyl Headlight Sealer or any other brand
• Spray Paint, Prime & Clear Coat (your choice if color)
• VHT Nightshades (for smoking corner reflector & Turn Signal lense)
• Wire Cutters, Connectors, Clamps, Sodering Iron (not required)
• Tie Down Straps or Vice Grips (You will need 4 straps or 8 vice grips. These are to force the light housing to seal properly when resealing)
• Rubber Gloves (powderless and dry)
• ..... I might be forgetting a few things, i will update this list as i progress through the build.
I have the lights, and I've started with taking them apart on video. I am ordering the halos and LED Boards tomorrow from JJ at Retroshop so hopefully they are here by the end of the week. In the meantime I will begin disassembling the headlight housings and preping and painting them. I have someone video recording the entire process so I can also include a video tutorial. I should be all done painting and prepping by the time the halos and boards arrive, so hopefully I can be done by the end of this weekend and have the guide up then.
• 2012 Ram 1500 RCSB Hemi • 22" SRT-10 Wheels Plastidipped Black w/ Bridgestone Tires • Smoked Taillights • Custom Quad Headlights • Opt-7 FluxBeam-X 6000k LED Lows • MicTuning 6000k LED Fogs • K&N 63 Series CAI • Flowmasters Muffler • Line-X Bed • OEM Black Badges All Around • 20% Tint All Around • Lund Tri-Fold Tonneau + plenty more coming soon...
What is being done:
Things needed:
