Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > 4th Gen DIY
4th Gen DIY
How to install Vararam
This is a discussion on How to install Vararam within the 4th Gen DIY forums, part of the 4th Gen : 2009 - Present category!
Like Tree22Likes
Reply
Old 12-20-2011, 06:55 AM   #1 (permalink)
Trupiano's Avatar
Registered User
Location: Hometown : Puyallup,WA Stationed : Little Rock, AR
Name: Steven [TRIP/TRUP]
Ram Year: 2010 Ram 2500 6.7L CTD Crew Cab
Engine: 6.7L CTD
Talking How to install Vararam
Vararam Air Grabber™ Ram Air Induction System for Dodge 2009-2012 Hemi Powered Trucks
Items needed for installation: •1. Flathead screwdriver/ Long reach •2. Box knife (if you choose to cut the shroud versus removal) •3. 10mm socket/ratchet •4. Approximately 15 minutes of time
Important : •Please completely read through all the instructions first before starting the installation of this product. If at any point you are uncomfortable attempting this installation on your own, please refer the installation to a qualified service technician. •Please email our technical staff at [email protected] with any questions.
•Step ONE: Remove the OEM air temp sensor by squeezing and pulling on the wiring harness.
•STEP TWO: Twist off the oil cap- This will allow you to remove the OEM engine cover. Simply lift up and the cover will come off. Don’t forget to put the oil cap back on after removing the cover.
•STEP THREE: Remove OEM intake hose using flat head screwdriver
•STEP FOUR: Remove the OEM air box- just pull up this will release with a good strong pull straight up.
•STEP FIVE: Remove the front shroud cover. Using your flat head , pry these round plastic push clips "UP". They will release with a stiff pull. Remove this OEM foam cover out of your way. (Optional) You may choose to cut out the center section at a later time , so that it may be reinstalled to give a more OEM look.
•STEP SIX: Move the wiring harness in front of the horn- you will need to clip or pull the wire holders as well as remove the horn bracket screws (10MM) Once the harness is put in front of the horn you will re-attach the horn assembly. This frees up the restriction caused by the harness.
•STEP SEVEN: Assembling the VR system. The easiest way to do this is to, attach the front wing to the upper plenum outside of the truck on a nice flat surface, like a kitchen table or workbench.
•STEP EIGHT: Install the air temp sensor at this time, push and twist, You may need to use some lube like W/D You will need your 10mm socket wrench and a screwdriver Install the screws and lock nuts as shown here.
•STEP NINE: You are now ready to place the system on the truck as one whole unit.
• STEP TEN: Remove the short 45 deg section of the PCV line, this will become your new PCV line. using this shorter end Simply reinstall this back on to the valve cover and push the chrome breather into the short 45 deg OEM hose, you can
rotate the hose in any position desired
Re-Learn time - You should at some point disconnect the negative battery cable for two hours then reconnect it. This will allow the ECU to reset the fuel trims, now simply drive normal for about 30 miles or so. This will allow the long term fuel trims to set in.
F.A.Q.
1. How often do I need to clean the airfilter?
About every 6-10,000 miles depending on the driving conditions
2. Do I need to worry about high water?
Not unless you drive in water that is 3ft or deeper. There are drains that will drain off excess water and moisture.
3. Do I need to remove the system to put oil in?
NO, simply use a funnel when putting oil. This will keep you from possibly making a mess when pouring.
Sponsored Ad
Register to remove this ad.
__________________
Trupiano is offline   Reply With Quote
Old 12-20-2011, 09:49 AM   #2 (permalink)
quietpeen's Avatar
Administrator
Ram Year: 2016 1500 Sport Crew Cab 4x4
Engine: Hemi 5.7
Default
very cool info
__________________
RamForum.com Administrator
quietpeen is offline   Reply With Quote
Old 12-20-2011, 08:24 PM   #3 (permalink)
Bigdaddy's Avatar
Ram Year: 2016
Engine: 6.4L Hemi
Default
Look good now do they work this might be one of my mod in the near future?
Bigdaddy is offline   Reply With Quote
Old 12-20-2011, 08:34 PM   #4 (permalink)
iSlacker816's Avatar
Ram Year: 2001
Engine: 5.9 (360ci) Magnum
Default
Nice write up!
__________________
2001 1500 Off Road Edition/5.9 Magnum/4.10 Gears - 16" XD798 Addict's - 33" Nitto Terra Grappler's - Linex Spray In - Glasspack Duals w/ Tips - Dash Cap - Spectre CAI Superchips Flaspaq 3865 - Husky Molded Floormats - Hughes Engine's Plenum Kit - Moose Mirrors - Strobe Light Kit - Vent Visors - LED Interior Lights
iSlacker816 is offline   Reply With Quote
Old 12-20-2011, 10:19 PM   #5 (permalink)
jojo750's Avatar
Ram Year: 2011
Engine: 5.7
Default
thanks.
was told by vararam today that they dont include instructions because they are available on 2 different dodge ram websites.
too bad i dont have a f*%@#@( laptop to carry it down to my truck so i can look at the pics while i do the install.
__________________
mcgaughy/belltech/BT catch can/magnaflow
jojo750 is offline   Reply With Quote
Old 12-20-2011, 10:44 PM   #6 (permalink)
0212353's Avatar
RF Admin / Vendor
Ram Year: 2010 1500 Crew, 2016 1500 Crew & 2015 Charger SRT392
Engine: 2x 5.7L & 6.4L
Send a message via AIM to 0212353 Send a message via MSN to 0212353 Send a message via Yahoo to 0212353
Default
Originally Posted by jojo750 View Post
thanks.
now thats service with a smile there!
hemiguy93 likes this.
0212353 is online now   Reply With Quote
Old 12-20-2011, 10:46 PM   #7 (permalink)
Trupiano's Avatar
Registered User
Engine: 6.7L CTD
Default
Seems Vararam really says F**K You to customers and dealers trying to buy/sell they're product. Seem totally counter-intuitive...
__________________
Old 12-24-2011, 05:49 PM   #8 (permalink)
jojo750's Avatar
Ram Year: 2011
Engine: 5.7
Default
those instructions leave some room for alot of error.
especially if you arent mechanically inclined (**hint hint. myself included).
took about 1hr but got it installed.
you have to remove the rubber grommet for the temp sensor, and reinstall on the red rubber boot. took me awhile to figure that out. the sensor fit good enough in the silicone boot without the grommet. but eventually, i decided i needed to put it in.
and the flat piece that is held onto the bigger section of airbox. the instruction are NOT clear about how to attach it. you can argue there are only 2 ways to get the piece to attach, and i took the time to check both ways. but eventually figured out exactly how the piece was meant to fit. but some clearer pics would definitely help out us dummies that are attempting to be shadetree mechanics.
all in all, its in and done. now we see about the performance.
i went from stock to k&n (2months) to vararam. hope it lives up to the hype.
Cormier3288 likes this.
__________________
Old 12-25-2011, 03:16 PM   #9 (permalink)
Krypt0n0tic's Avatar
Ram Year: 2010
Engine: 5.7 Hemi
Default
Where did u by it? Vararam website only shows 2002-2007 model. And how much is it?
__________________
2010 Hemi lonestar, 24's, flowmaster muffler, hid kit inside headlamp and foglights, tint, diablo predator, k&n air filter, 2/4 belltech drop.
Krypt0n0tic is offline   Reply With Quote
Old 12-25-2011, 03:23 PM   #10 (permalink)
jojo750's Avatar
Ram Year: 2011
Engine: 5.7
Default
i bought it directly from vararam. called them when it was released for the 4th gen's.
3rd strike is going to carry them. according to duane, it will be available sometime in january.
i paid $349 shipped. it was an introductory price with free shipping.
3rd strike had them listed for $299+shipping. might want to contact duane and see if anything is set in stone about the price and availability.
and its definitely quieter than my k&n CAI. by a mile.
__________________
Reply
Tags
how to install vararam, install help, intake installation, vararam diy, vararam install
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Vararam install JIMBOX Engine & Performance 0 01-27-2017 02:03 PM
Vararam install... Lhemi Engine & Performance 18 03-17-2016 11:11 AM
Vararam install? homebrew Engine & Performance 3 10-10-2014 11:40 AM
Vararam install Chadh1028 Engine & Performance 27 01-07-2014 07:26 PM
Any issues with Vararam install & batt disconnect? TB install questions Strange Ram Engine & Performance 8 07-18-2013 10:53 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
