Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > 4th Gen DIY
4th Gen DIY
How to install Vararam
This is a discussion on How to install Vararam within the 4th Gen DIY forums, part of the 4th Gen : 2009 - Present category!
Originally Posted by DavidRam Dude that's an awesome write up! Vararam should pay you for that to replace their shitty ...
Like Tree22Likes
Reply
Old 08-03-2016, 10:17 AM   #101 (permalink)
Tray Burge's Avatar
Ram Year: 2003
Engine: 5.7 Hemi
Default
Originally Posted by DavidRam View Post
Dude that's an awesome write up! Vararam should pay you for that to replace their shitty pictures and directions. Seriously, send it them...
Hey David,
I thought you sold your gorgeous Ram and bought a Jeep? Did you decide to keep that beautifully executed Ram, or are you already regretting letting her go? LOL! And, I wanted to ask you how much did your custom valve/coil cover cost, if you don't mind me asking.
Sponsored Ad
Register to remove this ad.
Tray Burge is offline   Reply With Quote
Old 09-27-2016, 06:20 PM   #102 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
Originally Posted by jackblackjeet View Post
I have borrowed the text from Post #1 and have added some annotations from my experience and some pictures from my install.
***Artwork on the Vararam filter lid was done by Tat2hemi, so if you like it, he's your guy***
•Step ONE: Remove the OEM air temp sensor by squeezing and pulling on the wiring harness.
•STEP TWO: Twist off the oil cap- This will allow you to remove the OEM engine cover. Simply lift up and the cover will come off. Don’t forget to put the oil cap back on after removing the cover.
* on my 2014, I did not need to remove the oil cap to remove the engine cover. Simply lift up and towards the front and it came right out* *Also, I performed this after steps 3 and 4*
•STEP THREE: Remove OEM intake hose using flat head screwdriver
•STEP FOUR: Remove the OEM air box- just pull up this will release with a good strong pull straight up.
*I broke one of my OEM air box tabs by pulling up too strong on this, so be careful*
•STEP FIVE: Remove the front shroud cover. Using your flat head , pry these round plastic push clips "UP". They will release with a stiff pull. Remove this OEM foam cover out of your way. (Optional) You may choose to cut out the center section at a later time , so that it may be reinstalled to give a more OEM look.
•STEP SIX: Move the wiring harness in front of the horn- you will need to clip or pull the wire holders as well as remove the horn bracket screws (10MM) Once the harness is put in front of the horn you will re-attach the horn assembly. This frees up the restriction caused by the harness.
*I did not need to do this for my 2014 so no pictures of this to share. *
•STEP SEVEN: Assembling the VR system. The easiest way to do this is to, attach the front wing to the upper plenum outside of the truck on a nice flat surface, like a kitchen table or workbench.
*I forgot to take pictures of this as well.*
•STEP EIGHT: Install the air temp sensor at this time, push and twist, You may need to use some lube like W/D You will need your 10mm socket wrench and a screwdriver Install the screws and lock nuts as shown here.
* no pictures of this either, I pushed my IAT in until the rubber o-ring was on the inside of the red tube that mounts on the throttle body. It was a perfect fit. Also be sure that you have your IAT in the correct direction, mine had a little lock pin that needed to be pointed straight up to allow air to flow through the sensor correctly.*
•STEP NINE: You are now ready to place the system on the truck as one whole unit.
* I did this after step 10, because once this thing is in place there isn't a lot of room to work on the PCV.*
• STEP TEN: Remove the short 45 deg section of the PCV line, this will become your new PCV line. using this shorter end Simply reinstall this back on to the valve cover and push the chrome breather into the short 45 deg OEM hose, you can
rotate the hose in any position desired
*the PCV line is the the black hose that has black foam cushioning around it. In my picture below it starts just behind the oil cap and goes to the OEM air box. You remove that main length of hose and the short 45 degree piece is sticking up behind the oil cap*
You can see the shiny chrome breather pretty good in this picture
• BONUS STEP 1: Cut a 2" x 2" section out of the upper left of the air dam to improve fitment.
• BONUS STEP 2: Trim the shroud so that it can be reinstalled for OEM look. In my picture I did not cut enough away and ended up going about 1 inch further into the shroud to allow more air. I used a cheap dremel with a plastic cutting disc.
FINISHED INSTALL PICS
pile of leftover OEM parts
TEST MPG Control Course (30 mile roundtrip to my office, low traffic because weekend, tested right before the install)
TEST MPG Vararam Installed (30 mile roundtrip to my office, low traffic because weekend, tested after 2 hours off batter was complete)
The whole install was pretty quick 40 minutes tops. I unhooked my battery before I started the install so that I wouldn't have to wait as long for the computer to reset. I had check engine light on for the rest of the day. I pulled everything apart to double check, eventually gave up and said I'd worry about it the next day and take to O'Reilly's to read codes, but that night the CEL was gone on it's own.
So the 2012 kit does work on the 2014?
john94si is offline   Reply With Quote
Old 09-27-2016, 09:45 PM   #103 (permalink)
Hemi450hp's Avatar
Ram Year: 2011 Ram 1500
Engine: 5.7L Hemi
Default
No it does not. The 2013+ kits use a longer coupler and different front wing that goes in front of the radiator.
__________________
2011 Ram 1500 - 11.99 @ 110.66MPH N/A
2011 Ram 1500 - 11.09 @ 120.13MPH Nitrous
2014 Ram 1500 - 12.38 @ 109.61MPH N/A
Hemi450hp is online now   Reply With Quote
Old 09-28-2016, 09:29 AM   #104 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
Moe do you sell them? if so how much for the 2014?
Old 09-28-2016, 09:46 AM   #105 (permalink)
Hemi450hp's Avatar
Engine: 5.7L Hemi
Default
Yes, we have about 30 kits in stock. Check out the link below.
http://www.moes-performance.com/Vararam_Air_Grabber_Intake_2009_16_Dodge_Ram_5_7L_ p/vr-hemi-4g.htm
rubes7202 likes this.
Reply
Tags
how to install vararam, install help, intake installation, vararam diy, vararam install
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Vararam install JIMBOX Engine & Performance 0 01-27-2017 02:03 PM
Vararam install... Lhemi Engine & Performance 18 03-17-2016 11:11 AM
Vararam install? homebrew Engine & Performance 3 10-10-2014 11:40 AM
Vararam install Chadh1028 Engine & Performance 27 01-07-2014 07:26 PM
Any issues with Vararam install & batt disconnect? TB install questions Strange Ram Engine & Performance 8 07-18-2013 10:53 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
