How to modify oem switch panels to use the dead buttons
Nick1500Josh
West Palm Beach, FL
Anyone know a store or part number for a switch like this size but in toggle instead of momentary. I went to radio shack and picked up a momentary but I need a toggle version too. The staff was not knowledgeable at all and I didn't see one in their stock. I've tried Home Depot. Pep boys. Discount auto parts. Radio shack. No one has one this small.
Stlram81
Nicely done. Was just thinking about those wasted buttons the other day!
R.L.K.
Bristol , Tn.
Bump ! To make easier to find
C
cgworth
So if im understandinproperly...The buton you installed are behind the factory empty spaces? So you still have the clean look, and push the empty space?
that is correct sir
C
cgworth
Radio shack should have them you just have to dig thru the drawers. all the radio shacks in my area closed down so i can no longer go there and look. you could think about using the Hazard switch and running a hidden toggle somewhere for the hazards or look thru a junk yard for another switch panel and see if you can figure out a way to remove just the hazard piece from the the panel you find
C
cgworth
either of these look like they would work, they both say they have an on off function. not sure of the size or if they would work , its hard to say without having them in hand
(28).Mini Push Button Switch-Dip Switch Toggle Switch Rocker Switch Micro Switch Switches Pacer Technology Co., Ltd. (Member of ECE group)
kidfresh
cummings 6.7
any way i can see these pics
the photos say something about 3rd party hosting from photobucket or something and im very interested in this post. any help>
ScottFL
U.S. Navy Gulf War Vet
Florida
2016 RAM 1500 Laramie Longhorn 4X4
HEMI 5.7
Photobucket ruined many forum posts....
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
:hail:
Bump.
Gordinho80
Monroe, NJ
2012 1500 Big Horn
OMG! Thank you! I knew there had to be a way to use those dead switches!
