HOW TO: painting and baking your headlights the right way, many pics
2013Ram1500
Texas
2013 CC 1500 4x4
Anyone have a specific sealant they use when putting them back together?
Cruizer
Ohio
2010 Sport 4x4 QC
^^ I'm curious about this as well.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
butyl is best.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
no, some auto parts stores - or paint stores. its used for windshields.
hawg44
ward, arkansas
so on a 2013 whats the census on oven temp and bake time?
and what type of paint and prep?
2013Ram1500
Texas
2013 CC 1500 4x4
250 is a good temp and I'd say at least 15 minutes. The first time I attempted it I was anxious about melting them so I only did 5-10 minutes and it was difficult. When I did it for 15 it was much easier and you could probably go a little bit longer if you wanted.
2013Ram1500
Texas
2013 CC 1500 4x4
I used Plastidip on mine because I had a can left over
*tim*
really wish there was still pics
gunner1374
In the 405!!!
HEMI 5.7
I went 250 for 15 minutes and then tried. If they dont come apart easily, put back in for 5 more and try again. If still not apart, try another 5. They will come apart. On cleaning the old sealant out of the channel, DO NOT TRY IT WITH THEM COLD! It is a HUGE pain in the ass and comes out in pieces. Instead, put the housing in at the same 250 for 5 minutes. Pull them out and, using a small narrow flat screwdriver, start working around the sealant. If it doesnt budge, go back in for 5 more minutes. Once you get the magic temp, it will pry out in a solid piece as long as the temp is right. When it gets hard to come off again, then back in for a few minutes and work at it again. I only had maybe 1-2 minutes to work them when out of the oven before it started "sticking" again. Back in the oven for a few minutes and work them again for 1-2 minutes. Sounds dificult, but very easy and the look is well worth it! Good luck!
Little Red
NY, USA
Looks badass!
I'm going to do this to mine when I install projectors and hid's from JJ.
*tim*
Anyone else having trouble viewing the first 30 pics?
I can see a few but most of them won't load.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
yodge
Huntington Beach CA
2013 ram 1500 hemi
Cool! Be warned, people who do this mod on street trucks have reported the headlight inards not being able to handle the weight of the Dually and cracking / failing.
I noticed that the dually pod is pretty heavy compared to the headlight plastic. I'm going to try and figure out a way to cement it in there enough so that the weight is somewhat evenly displaced. Any recommendations ?
evanblain
Alberta, Canada
What about something underneath? Like add some kind of support underneath the bezel.
