Trupiano
Registered User
- Jun 27, 2010
- 10,981
- 725
- 2010 Ram 2500 6.7L CTD Crew Cab
- 6.7L CTD
Here's a great little guide on the harness install, just in case anyone ever needs it.
Here is how to hook up your wiring harness
Here is what get hooked up to what:
1. Connect to Left Ballast input
2. Connect to Right Ballast input
NOTE: 1 & 2 may be reversed depending on where your battery is and how long the
connector cable legs are.
3. Connect to the Positive + side of your battery.
4. Connect to the Negative - side of your battery.
Note: the negative power leg may also be connected to a solid chassis ground.
5. Connect to your car's stock headlight power cable.
Note: This connection can be to either the right or left headlight power connector.
The other headlight connector is no longer used and should be covered in electrical tape or other material to protect the connector ends from the environment.
How it works:
The Headlight power connector (5) powers the relay (6) which provides power
directly from the battery (3 & 4) through a fuse (7) to the HID ballasts (1 & 2).
Got it?
Aim your lights to somewhat look like this:
How it works:
Got it?
