INFO - 2013-2018 8.4A /AN FW Notes (RA3/VP3-NA & RA4/VP4-NA & UAx)
Dodgetk81
I kinda of rigged half taking out the old one and using the new. When I started the vehicle came right on and said Radio Lock Please start vehicle. I did. However that blocked the screen and turned the air on which worked.
(I add picture shortly)
Then said enter Anti - Theft Code which I don't have so is this a NAV solution or ???
You will need to call the dealer with the radio part or serial number and the vin of the donor truck. If they are not willing, navrepair.com I think will do it for $20
GYSOT
2014 Ram 1500
Here is the other
GYSOT
2014 Ram 1500
I don't mind spending 20 bucks but will the rest work or is it throwing 20 more dollars away?
SitKneelBend
St. Louis
3.6 Pentastar
You can sell the radio with the unlock code as a bonus (added to the selling price). It will be the same code in any installed vehicle.
GYSOT
2014 Ram 1500
Got an email from Nav and he said
2016 is not compatible with 13/14 vehicles. A 2014 radio is ideal
So I asked if I shipped to them could he be compatible otherwise I will be looking for another radio out of a 2014. I can't return this one so will make a nice paper weight on my desk. I am kidding I think, I think they will take it back when they can find a another buyer.
ogutierr66
Diesel
Status update: Reinstalled the HVAC Controller 68268187AA and let it blink for a while, then it worked as the other controller 68105017AE. But this 87AA controller for 2016 RAM 7 speed has the same issue with memory retention of the HVAC. So two radios and two controller with no memory retention! I GOTTA believe it has to be a 2016 truck issue! Everything works great !! I love the Siri, XM live and HD. I control all HVAC functions. I am chasing the cherry on top though!! Next step is to get the truck flashed to a RA4. I just hate talking to dealers, they are clueless or by the book and don't help very much!
R.L.K.
Bristol , Tn.
Good luck Sir !
Mpgrimm2
Mpgrimm2
SC
2022 Ram 1500 (5th Gen)
5.7L
I say get the code and try it first. If your 2014 is already a 7 speed fan, then it's no big deal to test everything out with the new bezel (to also see what the fw is).
There is already one guy asking about a 2016 RA4 here because of the Siri handsfree feature. As mentioned, you should be able to sell it and least recoup your $$ if it doesn't work.
Mpgrimm2
Mpgrimm2
SC
5.7L
I have been getting conflicting feedback on the 2016 RA4's, but yes, a 2014 RA4 is ideal, however, the 2015+ RA4's have the most current Map/NAV database.
Do you have the conversion harness and new bezel yet to check the radio's FW?
if so, go into dealer mode and see what the FW version is...
* Dealer Mode (Use this to identify your Radio's P/N and S/N !)
......... Hold Hot+Cold+Front defrost buttons for 5 seconds
* Engineering Mode
........ Hold Hot+cold buttons for 5 seconds
SitKneelBend
St. Louis
3.6 Pentastar
So anyone else who has done this MOD still have a free SXM connection? Mine expired on Jan 3rd but is still working.
GYSOT
2014 Ram 1500
I ordered the code, I will need when I sell anyway.
GYSOT
2014 Ram 1500
HVAC P68105017AE
Center Stack 5VD75JXPAA
SitKneelBend
St. Louis
3.6 Pentastar
You don't necessarily need it, but it is a nice plus when buying. I would imagine a 2016 radio could demand a higher price then 13 and 14 radios since there aren't as many out there right now. Not to mention the newer features and map data.
Mpgrimm2
Mpgrimm2
SC
5.7L
HVAC P68105017AE
Do you have a factory 4 speed fan blower or 7 speed fan blower??
(That is an HVAC module for the 4 speed to 7 speed conversion)
Your center stack will work, from post 16 of the conversion thread (most people reference the 1UJ96 PN )...
Sent from my LG G4 on Tapatalk.
GYSOT
2014 Ram 1500
My factory system was a 7 speed fan.
GYSOT
2014 Ram 1500
F Me I order the right one back in October and just opened it and looking through the other feed and they sent me the wrong one. Damn it.
Mpgrimm2
Mpgrimm2
SC
5.7L
That sucks man. Someone will buy it off you as well. Do you already have the conversion harness?
GYSOT
2014 Ram 1500
yes I do
Way to confirm that is right?
Mpgrimm2
Mpgrimm2
SC
5.7L
yes I do
Yes, check it against the 7 speed fan harness schematic on post 2 of the conversion thread.
Primary difference is pin 17 is connected together at both connectors and also pins 8, 10, & 12 I think are also unique to the 7 speed conversion harness.
PS: don't use that 4 to 7speed HVAC module in your truck with the harness. But you can test the bezel, harness, and 2016 radio without any risk
