DISCLAIMER: I am not responsible for you or what you do with your radio. It is up to you to know if these are correct for you or not. Use these files absolutely at your own risk. I am simply trying to help those that can't get a verified VIN for their 8.4AN swap or want to roll back to previous firmware for some reason.
(CNET) MD5 Checker 2.31 (creator)
(GET IT! You should check your downloads against MD5’s whenever they’re posted to verify a good download.)
2014 8.4AN (RA4/VP4 NA, 68224525AB)
Verified P/N's from members:
- 68224525AB ... Jared 4.7
- 68224525AD ... Tallsilver
- 68224525AE ... (Avgas & LQK Ebay listing)
- 68224525AG ... OutlawTrucker
- 68224525ZH ... SitKneelBend
- 68224525AH ... (Vin Verified via LakelandMotors Parts clerk, CptWing, & Mpgrimm2)
Latest Version: 18.45.01
** FYI. The latest v18.45.01 update for ALL 13-17 Ra3 VP3-NA and RA4 VP4-NA radios is in a separate thread at the moment & appears to require SW version 17.11.x or higher **
ROLL-UP INFO: FOTA 18.11.x & uC D/L 18.45.01 SW Update 13-17 RA3/Vp3-NA & Ra4 VP4-NA.
NOTE: The only files that should be on your Fat32 4gb+ Thumbdrive when ready will be "swdl.iso and swdl.upd"
v17.43.01 Fw Link (
2014 ONLY!) and
Update Directions Link
NOTE:
(Cargo Cam Button removed w/Backup Cam!)
List of Changes:
TSB 08-068-18 My13_My14 17.43.01.pdf
MD5: BD003E575E11988ABD4FACEDEA6AB73F
v.17.11.07 Fw Link (2014 ONLY!) and
NOTE:
ONLY Version that supports Backup Cam & Cargo Cam!
List of changes: FCA
tsb_08-071-17 MY13_MY14 RA4 VP4-NA v17.11.07.pdf
MD5: ADF1ADCAA4DD73CE9519C69413D414E5
