Flyguytki
I added a Bakflip G2 Tonneau Cover the other day and decided I needed to install some LED lights in the bed. I decided to go with blue strip lights to match the truck. I tapped into the power off the trailer wiring harness, made a plate to mount a simple toggle switch and wired three strips of lights. Each strip has a waterproof plug separating them, this way if the cover needs to be removed you can unplug the lights and pull the cover off. Pretty happy with the turnout, It will be interesting to see how well the adhesive on the LED strips holds up in the southern heat.
