Leds
dereck56
Recently I bought a 2016 big horn and I'm loving it. The first thing I noticed is all the lights were not led so I went to supper bright leds and bought some can bus ones to start out. Their is a huge diffrence the left on is led and the right is not. 918e3f323eabd13332be0f1b5e04216c.jpg
Sent from my SAMSUNG-SM-G928A using Tapatalk
jlafollette07
One of the first things I change out on my vehicles. The White light looks so much better.
polock48
NH
What is the part number and where did you buy them at?
Thanks
D
dereck56
I'm not sure about the part numbers I can look latter but I went to supperbrightled.com and they have a bulb finder for your truck. You then choose which one u want such as map lights or license plate lights. Make sure u buy the ones that say can bus leds because they won't give u an error code.
DarthMegaHD
Henderson, NV
Hemi 6.4 MegaCab 4x4 Black Edition
Cool I'm gonna check out that site, thanks for the tip
D
dereck56
Just an update on this I ordered my dome light and map light with the can bus white led. I got no error code again and tomorrow I should be getting my 3rd break light leds and foot well lights but more pics to come as I finish them.e60c19ef5140a3987ab41c31d1e9fef6.jpg
D
dereck56
Also has anyone gotten their tail light led from supper bright or another websire? Was it just swapping the lights or did u need resistors?
Eww707
2013 Ram 1500 Sport
I have led reverse lights that I got off eBay. They work great and bright with no codes thrown or resistors either.
Sent from my SM-G900W8 using Tapatalk
Stlram21
St. Charles, MO
Guess I should consider myself lucky I live two exits away from both superbrightleds and diode dynamics lol. I highly reccomend both companies for any leds
D
dereck56
Just a little update again I finally received my third break light leds and all my interior is cool white. My last set to purchase will be the tail lights. Also thanks everyone for the help.
D
dereck56
D
dereck56
They are, they are really worth getting in my opinion.
JaredRAM2015
Kilgore, TX
HEMI 5.7
I went with Enlight, nothing against SuperBrightLed's, I have used them several times. Just read something good about Enlight and figured I would give a smaller company my business.
D
dereck56
I went to supper brightled.com and used the bulb finder for my truck. But these are the ones I used for my map lights,footwell light, and third break light. e88e43499053931dc23dfcddedd770bb.jpg
Donelam304
Madison, West by God Virginia
HEMI 6.4
Is it best to use the can bus ones. Or does it matter. I have a 2014 RAM 2500 Crew Cab. I have seen in some posts that people talk about codes being thrown.
D
dereck56
It is best to use can bus bulbs they help the issue of getting codes. I have a 2016 1500 bighorn And I have no codes. Yes my lights still work the same as before they are just a lot brighter.
JaredRAM2015
Kilgore, TX
HEMI 5.7
I tried non CAN bus bulbs in the interior of my 2015. They worked.... sometimes...
I swapped them out for CAN bus bulbs and they work great!
