Lifts and levels
goodguy11
HEMI 5.7
Looking for some idea for my 2016 half ton sport as far as a lift or level go. Post pics if y'all would please.
scisteve
Riverside, california
12" Bulletproof Suspension on 38x15.50-20
joeygster
Ancaster, Ontario
4" Superlift with 35x12.5x20's
goodguy11
goodguy11
HEMI 5.7
Going to the dealer to find out if it's possible to put 2500 rear coils in my 1500. That'll give me 2.5 inches in the rear and then I can out a 2.5 level in the front
Ox69
Baltimore M.D
6" lift is the way to go! :happy107:
nickster82
canada
2" level with 35 12.50 r17 fuels +14 offset no rubbing no triming
mpittman
Indiana
2015 Big Horn Crew Cab
Could I get you to measure your truck from the highest cab point to the ground? I'm trying to figure out if I can still fit in my garage door with a 4" lift?
WillO
South Florida
Why not measure your truck height and then measure your garage door height then you'll know
mpittman
Indiana
I already know what my stock height is, and my garage door height is... but I'm also wanting to add 35's along with the 4" lift, and I also know that everything does not always measure true once all mounted and installed. I currently have 5" of clearance from the top of my shark fin to the top of the door, that is with no lift or level, and the stock 275/60/20 tires. I can take the shark fin off if I need to, as i don't use anything that it is needed for.
WillO
South Florida
Ahh I see.
With a pre lift height of only 5 inches, You may have to cut out a notch in the garage header for the fin lol
Ferro
4" zone lift with 35s.
