joeygster
- Sep 21, 2015
- 1,834
- 1,220
- Ancaster, Ontario
- 2016 Ram 1500 Sport Crew Bright White
- Hemi 5.7
Could I get you to measure your truck from the highest cab point to the ground? I'm trying to figure out if I can still fit in my garage door with a 4" lift?
Check out my build thread. There is a lot of info in it on this issue.
http://www.ramforum.com/f38/finally_2016_ram_1500_sport_crew-85380/
Specifically, check the following posts within that thread.
Post 36: Pics of Ram fit under garage door opening.
http://www.ramforum.com/1319683-post36.html
Post 68: Pic of the roof puck
http://www.ramforum.com/1350776-post68.html
I’ve got the puck antenna instead of the shark fin.
Mine fit into a garage with a 7' door & weather stripping that leaves me an opening of approximately 82 3/4". Plus my driveway slopes up to the garage so that will help too.....
I also changed the open check on my garage door and gain a couple more inches for the door so it was raised above my weatherstripping.
I measured for you, but I’m running 275-65-20’s for the winter & they are almost an inch shorter in diameter than my 35’s.
That being said….right now my truck sits at approx. 80” tall including the puck, so with the 35’s I’m at approx. 81” tall.
