jgruberman
- Oct 17, 2015
- 636
- 147
- 2015
- EcoDiesel 3.0L
Summary:
I read all about the 2 kits available now and all the issues that the trucks were having with the HIS systems and I just couldn't bring myself to spending $200 for an HID kit. So I spent $90 on Amazon and got everything working... here's what I used and how I used it:
***Note, this was done on a 2015 Ram 1500 Lonestar edition with quad headlights***
What I Used:
(If I can't put external links on here, then please remove them)
Kensun HID Kit - https://www.amazon.com/gp/product/B004ZF4NAY/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
OPT7 Relay Harness - https://www.amazon.com/gp/product/B00J7TZEGA/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
OPT7 Inline Capacitors - https://www.amazon.com/gp/product/B00J8QNNWY/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Headlight Removal:
I used this video from about 1:16 to 5:16 to get the headlights out and ready for the installation: https://www.youtube.com/watch?v=ptcqtJg189s
How I Wired Mine:
I'm not sure that pictures are necessary, but better too much than not enough. I'm going on the assumption that if you're reading this, then you know how to install the HID system and wire it to the relay. If you don't, then there should be instructions in the box
The headlights ready for work
The capacitors connected inline between the relay harness and the ballast
How I wired the relay - Power to the battery, ground to a screw in the engine compartment and I unclipped the fuse box and laid the relay in there and clipped it back in place so I could get to the relay if need be. Once the fuse box is back in place, it holds the relay in place perfectly
WHERE I placed the driver side ballast, bottom of the fuse box compartment it fits perfectly but I used double sided tape anyway:
You can barely see it, but the wire tucked behind the existing wire looming across the front of the compartment. Probably a good idea to use zipties to attach them together
Where I have the other ballast attached, with a self tapping screw into the frame behind the headlight
The headlight itself with a 1" hole drilled into the bulb housing cover to use the built in grommet
Again, in line capacitor between the relay and the ballast with a ziptie on the other side
Put it all back together and turn it on!
Different angle of the lights... They're not nearly as blue as the above pic makes them look:
I drove it around and no issues... will continue to keep an eye on it over the next few days and weeks to make sure it keeps working - so far so good! If you have any questions, I'd be happy to try and help
What I Used:
Headlight Removal:
How I Wired Mine:
