jon0m0berry
- Mar 4, 2015
- 133
- 22
- 2010
- hemi 5.7
I just got a used 2010 hemi 4x4 crew cab 5 speed and am loving it. but its at 78500 miles and there is no record of the tranny fluid, filter or transfer case fluid being done at the 60000 mile mark. my truck didn't come with a Manuel but I found one online. it did tell me what kind of fluid is needed, but it doesn't give how much tranny fluid or transfer case fluid will be needed nor does it specify what of the two fluids it says the transfer case calls for, ATF+4 or NVG 246 fluid. how can I tell what transfer case fluid ill need and how much of both will I need? I've never done a tranny or transfer case fluid/filter change before. im no mechanic but im also not 100% new to working on cars either. is there anything I need to watch for while doing this? also on a side note while I was checking my tranny fluid at normal operating temp it was a little low and I added fluid and I think I over filled it 1/2-2/3 of a quart. do I need to worry? any info helps thank you
