badfish888
- Jun 27, 2010
- 1,092
- 89
- Va beach
- 2012 hemi express
- 5.7L Hemi
ill give it my best shot........
parts needed
-3"raceland cutout kit
-3, 3" butt joint band clamps (walker engineering) from summit
-1 3" turndown (walker engineering)
-sawzall or hack saw
- 14 mil socket for clamps
-lots a zip ties
- wire connectors and crimpers
install time 40 min
well, photo bucket and my computer are being ***-tarts
and I dunno when I will b off duty again soooo im going to describe it the best I can with key pics...
-the connector for the cutout is ziptied with about 1 foot of hanging slack to the last cross member on the transmission.
- then it runs along the inside of the frame (zip tie as needed) until the frame starts to bend up.
- there were 2 holes on my frame hat I ziptied the wire to and then it goes over the top of the frame, between the fender liner and the engine bay.
- I have a zip tie securing it to the back of the abs sensor wire that goes through the fender liner and then to the hard line behind my intake.
- from there it is secured o the small tab with a hole in it, and run to the same tab on opposite side above the brake booster
this is the passenger side
parts needed
-lots a zip ties
install time 40 min
