Tapping into cargo light
stebs
6.7 cummins HO
I needed to tap into the cargo light feed to switch some lighting i added to a work trailer, so heres what I did.
The cargo light gets its power from the cluster. It is a white wire with a tan stripe that is found in the 43 pin harness to the left of the brake pedal inside the cab, and is pin 22 i believe in that harness (its right next to an orange wire). The wire went along under the door sills on the drivers side.
I poked an 18ga wire through the grommet that the parking brake cable goes through in order to get the wire outside the cab. From there, i zip-tied it up to the harness that goes clear back to the trailer plug.
Since the cargo light gets its power from the cluster, I quick-spliced a fuse holder onto the wire under the door sill panel, and butt-spliced my 18ga wire to the fuse lead. I fused this at 2 amp since it was the smallest ATO fuse I could find in my area. At the other end of my 18ga wire, i spliced in a diode (radioshack #276-1103), and then spliced my relay connection to the other end of the diode. (note: I also taped a short piece of 10ga wire alongside my first diode connection to add some strength) I also strapped a diode across the relay coil as well to use as a suppression diode (reverse polarity)(google diodes on relays for details) to stop the back emf that occurs when relay coils de-energize). I used the diodes to protect the cluster when the coil de-energizes. I then provided ground by just bolting a ground wire through an open hole in the frame.
The truck also has an add a harness on it to add a 7 pin plug inside the bed for a gooseneck trailer. I cut the B+ wire in the add-a-harness and put my relay there, so that the relay switches the B+ on and off. I had to go by actual pins on the harness instead of wire color because the add-a-harness used different colors than the truck wiring.
Here is where I quick-spliced the fuse holder in under the doorsill. The grommet for the parking brake is near the right side of the pic. The fuse holder is hard to see here, but it is right below the red butt splice at the top left of the pic. The brown wire is my new wire that I added that goes clear to the back of the truck.
Here is the relay spliced into the B+ wire on the add-a-harness. The white wire is my relay ground wire that goes to the frame.
So now, I can switch the power to the B+ terminal on the 7 pin trailer plug by turning the cargo light on and off. If you wanted to add lighting inside your bed, You could tap off of that B+ wire that goes to the trailer plug, as it is hot all the time, even with the key off (it is fed by the 40 amp trailer tow fuse)
stretch78681
Texas Hill Country
5.7 squirrel cage
Good information to have. I am planning to put a set of LED running lights under the rear bumper. I wanted them to be independent of the backup lights. Since my cargo lights are now LED, I won't be running a relay; only an additional fuse at the white/tan tap.
w6pea
U.S.Marine Corps Veteran
San Diego, Mexifornia
2016 Ram 2500 "Laramie" 4x2 CC/LB SRW 6.7L CTD Leer 122 Campershell
6.7L IL6 Cummins Turbo Diesel
Just about what I am going to be doing also. Thanks for the info.:)
kegger
3.6 pentastar
Is this the cargo light switch you guys are talking about? The little button on the left? That's the button I would like to turn on and off the backup lights with, as well as when I put the truck into reverse. Sorry about the pic some reason it fell over lol
Rzrman328
The treeline
Yes.
kegger
3.6 pentastar
Thank you sir!
sbarron
Wasilla, Alaska
I did the same sort of thing bit a little more complicated. I ran my bed lights, puddle (rock) lights, and aux reverse lights to two different relays isolated by a diode. I can turn my flush mount aux lights either by putting truck into reverse, turning on the cargo light with the switch or hitting unlock on the fob. The puddle lights and bed lights also come on with the fib/cargo light switch. As the two relays are isolated by the diode, only the aux reverse lights come on when the truck is put in reverse.
http://www.ramforum.com/f41/bed_lig..._mount_reverse_light_install_pic_heavy-66687/
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
resurrecting since I want to tie into my existing factory bed light and add a few LED pods or strips deeper along the bed rails. Is this a simple thing?
kad
Hudson Valley, NY
5.7L HEMI
I think that what you'll need to watch for is the current draw (amperage). I'm not sure what circuit the factory bed lights are on or if they are monitored by the can-bus system. If they are, then the truck may shut the circuit down if it senses more amperage draw than it expects on that circuit. To be safe, what I would do is tap the existing bed light line to trigger a relay for the additional lights and get the actual power for the additional ones from elsewhere. The +12v line for the trailer connector is a popular option for that. My truck is a '14 and does not have the factory bed lights. I'm planning on attempting to install some aftermarket bed lights this weekend and I plan to trigger a relay from the cargo light and tap as described for power. The bed lights I have draw about .7 amp total and from what I've read, 0.25 amps is the most you can overdraw the CL circuit before the truck shuts it down.
-K
shadowhawk
Southeast WI
I may just end up running new wires. I bought an in-line fuse and on/off switch. I just have to figure out where to draw power, and where to drill for the switch.
shadowhawk
Southeast WI
Kad, are you going to put a fuse in there somewhere?
kad
Hudson Valley, NY
5.7L HEMI
Yes, it's always a good idea to do so and since the cargo light feed comes from the EVIC it's especially important for this, I'd rather not have a problem with a $20 bed light take out a $500 EVIC. :) The relay draws almost nothing in normal operation (<100 milliamps for the one I'm using) so a 1 amp or even a half amp if I can find one will work fine. I might even go old school and use a glass fuse since I can get those in 1/4 amp. A 1 amp on the power line as well will keep any issues from affecting the trailer feed. I spent the weekend doing yard work so the bed lights got delayed, again.
-K
6.4 L
Did you ever get this done? If so can you post a photo of how/where you spliced into the trailer harness +12v?
-K
kad
Hudson Valley, NY
5.7L HEMI
I haven't got it done yet and given the weather, unless we get a December heat wave (which we get about 1 year in 3) I probably won't get it done until spring but I've got the parts sitting here. I'm using one of these:
https://www.amazon.com/gp/product/B0009FJ38Q
That way I'm not cutting into the existing wires and I'll have the needed feeds to put in a tailgate light bar as well.
-K
