Did you ever consider adding the OEM chsmsl cam.....
Anyway I see you are using the RA1 / RA2 radio bezel l am trying to sell my OEM autoparts bezel for your 8.4 will make it look like it came that way from the factory. Pics in the for sale section
Great write-up....FYI, there appears to be the same camera on amazon with free prime shippeing for $17.99.
I'm trying to remember if the wiring of the lockpick Air v2 has seperate plugs for the turn signal and front cameras or if you have to wire them into the supplied harness. Can you tell me how yours plugged into the lockpick? Did I miss it in the write-up?
I'm curious to know how seamless the turn signals cam work. I am finding controlling the lock pick air is sometimes glitchy. Though I have not tried the remote yet still fiddling with it a bit.
I wonder how hard it would be to wire up all 4 cameras and make a DIY "dashcam" recorder with all 4 views at once.
You should be fine drilling into the paint. Keep the drilling moving fast and apply steady , gentle pressure to avoid cracking. I did it on my bumper to route the wires into my license plate and the paint was not cracking. I've only noticed the paint cracking on metal factory holes.one more question- I am putting in all new door speakers at the same time, so the panels will be off. I am freaked the hell out about popping that mirror off. Can I drill the hole from below and snake the wire into the truck you think? from that triangle piece where the power from the mirrors goes thru?
