fordtech90
- Sep 27, 2015
- 420
- 104
- Jonesboro, La 71251
- 2013
- Hemi 5.7
So first off let me say that I am not a professional painter. I'm a jack of all trades with the use of google and learn from trial and error. So if any of you professionals wanna chime in some tips you are more than welcome to. With that being said let's start this off
1. I plasti dipped my tips about 1 year ago and have been procrastinating actually painting them permanently. So I must remove the old dip which was much harder than you can imagine.
2. So I went to Walmart and got some 80 grit sand paper and some paint stripper. I took the tips off and first washed them with dawn and got water to remove any mud and debris. I let them dry for about 2 hours.
3. I sprayed them with the stripper and let it sit 39 mins or so and use a rag with warm water to wipe away chemical and then used 80 grit paper to remove paint. I did this process 3 times until all paint was removed.
4. I then washed them with dawn again and rinsed them to remove all chemicals so paint will stick. I went over them 1 last quick time to make sure they were good and roughed up to apply paint.
5. They are currently drying and will let them dry over night and will primer them tomorrow after work. So stay tuned!!!!
