Watch "How to install a lift kit on a 2014 RAM 1500 4x4 (Bilstein 5100 - front)" on Y
R.L.K.
Bristol , Tn.
https://youtu.be/GpLJIln6VBA
This video would've been nice to find before I installed my bilsteins and mevotech UCA'S , my install went fine , but for those interested in installing the Bilstein 5100s and you don't normally do this kinda stuff this video SHOULD GIVE YOU THE CONFIDENCE TO DO THE JOB !
Hope this helps somebody !
See below for pics of my install.
Painted the MEVOTECS with VHT Roll bar & chassis paint from Advance Auto.
OEM Installed UCA'S and strut.
Everything removed .
Bilstein shock set to + 2.8" and Mevotech UCA installed .
Almost a perfect level for me ! +.250" in the rear .
Picture above is a before picture.
Below is an after .
Jmhm17
Massachusetts
5.7L HEMI
Just and FYI, any components that you want to protect you should paint with a rubberized under-coating paint. I sprayed the whole underside of my truck, rear axle, diff, frame, control arms - everything that was not a moving part, and it survived a very bad winter here in the northeast. Not one bit of it had peeled off and no rust..
Nice write up btw
Edit: why did you replace the UCA's?
R.L.K.
R.L.K.
Bristol , Tn.
Nice write up btw
I only replaced the UCA For cheep insurance due to a few reports of upper ball joints popping up after a level ( I think the levels that caused this wer spacer kits ? ) nevertheless @ $49.00 ea for beefier UCAs with greasable ball joints , and I was gonna have the Balljoint loose for the bils 5100 install so it was literally 2ea more bolts ..
Cheep insurance. ..
R.L.K.
R.L.K.
Bristol , Tn.
I folllowed that video. I believe he over toques his sway bar links. But otherwise a good video. Oh and awesome truck!!
I agree on the tq of the sway bar , I didn't actually disconnect my sway bar , just loosened it up and pushed the lower arm down by hand to aid in installing the Bilstein strut assy .
He also did not clearly show the install of the flat washer prior to installing the upper spring seat , and NOT under the nut on the very top holding the assy together .
My advice to anyone installing bilsteins shocks .....look at the instructions sheet with the Bilsteins and make sure you install the flat washer in the proper location !
Installing the flat washer under the top nut has been reported to causing a clunking sound after a while .
Hope this helps !
R.L.K.
R.L.K.
Bristol , Tn.
Not sure if your housings are blacked out or not, or if its the lighting. But your truck would look sick with dark headlights..
It's just the lighting , mine are the chrome ones , I want dark ones sooooo bad , it's on my list for sure , I'm saving for a lift ,tires & wheels though !
Jmhm17
Massachusetts
5.7L HEMI
Just bake em and spray. if you screw it up then it gives you a legit reason to buy them lol. Get some Depos on Ebay I think they are like 200-250.. but again.. only if you break em
R.L.K.
R.L.K.
Bristol , Tn.
I just might do that after the new year , Santa might come through for me on some !
PHILLYRT
What kind of time frame am I looking at for the 5100 install with the uca swap while im at it? AND is the Mevotech much better than the stock setup?
Below is an after .
R.L.K.
R.L.K.
Bristol , Tn.
I would allow all day , but if your familiar with this type of work then about 4 hours , the first Side took me about 2.5 hrs , the second about 1.5 hrs I also rotated my tires in this process , I was using Jacks and stands by myself ...
You don't have to change UCA'S, I did for cheep insurance.
I do feel the Mevotecs are considerably stout er than stock ...
Hope this helps !
R.L.K.
R.L.K.
Bristol , Tn.
Black/darker headlights would look really good!
I have to ask, how did you take the first picture, it's tripping me out. :crazy:
The UCA'S are hanging from my deck .by wire , I'm standing under my deck . Lol i.never thought about it till you said something .
It kinda looks like they are suspended in mid air...
EMDubYa
I used this video when doing my install recently and it was very helpful. However, on my '09 it was a bit of a booger as I had to work the drivers side a bit to get it LCA mount. As a result, the CV slid out of its seat and I had to tend to that to get it back in. Somewhere in the process i guess that punctured the boot and so I had to repair that the next weekend.
R.L.K.
R.L.K.
Bristol , Tn.
Thanks buddy , I'm still liking your Fox shocks with the external reservoirs!
When I install my 6" lift I may do the Fox set up then ,but I'll probably wait till I need new shocks because in very happy with my bilsteins for now .
Like you though Sir , if I end up with any Rake at all with the 5" rear coils I'll install the taller Fox shocks immediately ! Lol I can't stand Rake ....
Look what I'm installing right now !
It's the RED Billet under the hood dress up kit I got off " Pull Ya " a member here .
Merry Christmas to my truck !
R.L.K.
R.L.K.
Bristol , Tn.
Bump .
Wow I forgot all about this litle thread
R.L.K.
R.L.K.
Bristol , Tn.
Bump , just because
crazykid1994
Florida
Can't seem to get the center nut out from the strut. Any quick ideas?
