Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Tech Info > 3rd Gen DIY
Sponsored Ads
Register to remove these ads.
3rd Gen DIY
03 TMR Delete Mod
This is a discussion on 03 TMR Delete Mod within the 3rd Gen DIY forums, part of the Tech Info category!
Register to remove these ads. It's free! The 03 TMR Delete Mod comes up every now and then and only ...
Reply
Old 01-17-2011, 02:22 AM   #1 (permalink)
Redtruck-VA's Avatar
Ram Year: 2003
Engine: Hemi-5.7
Default 03 TMR Delete Mod
The 03 TMR Delete Mod comes up every now and then and only takes a couple of minutes and is free. So I searched around and found pictures from another forum and have posted the mod here for future reference. This mod can only be done on the 03 model, all the newer trucks need to buy a tuner. This is a no BS mod that cost nothing and works by removing the torque management request coming from the TCM to the PCM. I've had this mod installed on my 03 for a few years with no adverse side effects. If you are concerned it will hurt something then don't do it.
Location of TCM...
Remove center bolt and pull plug out.
Remove the red pin holder.
Pull wire from pin #10 and tape off the end. Put it all back together and test drive!
This is really very simple to do, locate the Yellow/Dark Green wire (#10) and remove from the plug or simply cut it leaving enough to reconnect if you ever want to. Fold back the ends and cover with heat shrink.
I don't know how to cut and paste from a PDF file but you can find the schematic on the 03 manual at "Transmission Control System" (8W-31-8).
Good luck....
__________________
PI_greg 2003 SXT-Hemi, AeroForce gage, w/wideband, TCI Flr Shifter, LP Gage, AutoMeter Shiftlite, High Idle Mod, K&N -77 CAI, Fastman TB, eFan, 180 stat, TMR, Sonnax, HD Trans Cooler, SC3865, PSC1, Edge 2800, DTT 4:10, LT's, Magnaflow duals, Crzy Spartan, Wtr/Meth injection, Mcgaughys 2/4.5 spindle kit, Monroe shocks, Caltracs, Aeon bumps, SRT-10 gage pillar
Redtruck-VA is offline   Reply With Quote
Old 01-17-2011, 01:58 PM   #2 (permalink)
Ram Year: 2003
Engine: custom 5.7/6.1 hemi hybrid
Default
That's awsome. What's actually different about your truck with this done compared to stock? Just wondering what it actually did for you so I can decide to do it this weekend possibly
RAMpage is offline   Reply With Quote
Old 01-17-2011, 02:58 PM   #3 (permalink)
AF_Hemi's Avatar
Ram Year: 2003 QCSB 4x4
Engine: 5.7
Send a message via AIM to AF_Hemi Send a message via Yahoo to AF_Hemi
Default
it will firm up/quicken the 1-2 shift at WOT. no other side effects.
__________________
Time for a new sig...
suggestions anyone?
AF_Hemi is offline   Reply With Quote
Old 01-20-2011, 04:21 AM   #4 (permalink)
Ram Year: 2003
Default
ok sounds like il be doing this for sure after this one last question lol. my new trannys gonna have a line pressure booster and a shift kit, doing the tmr delete on top of that i should still be ok??? i dont know jack about an ato tranny and dont want to be putting too much line pressure to it or something and end up messing it up again.
Old 01-20-2011, 04:42 AM   #5 (permalink)
Ram Year: 2003
Engine: Hemi-5.7
Default
You are fine, I have been running both TMR and Transgo together for a long time with no adverse side effects..
__________________
Old 01-20-2011, 08:54 AM   #6 (permalink)
03MopaRamman's Avatar
Ram Year: 2003 Forgottens
Engine: Hemi 5.7 (1 of 2)
Default
^^ x 2. For our 03 not sure if adding the line Booster Mod helps if you have installed the Transgo Resistor (which I did) that the instructions say not to if you have a Tuner (That doesn'y apply though for the 03 IMO). It is supposed to Boost the Line pressure hence why i didn't get that xtra Booster Mod. So then I have a great question. If adding the Line Pressure booster mod does a fellow remove the Transgo Resistor??
__________________
6.1 Cam/Springs/Rods/Oil pump-SC3865-85 mm Ported TB W/Grnd-K&N-Pwr Wire-E-Fan-Hooker Headers-Flo Tech Y Pipe-Magnaflow 18" Dumped-B&M Shifter-TCI 2600 TC-Transgo HD w/Resist-TMR Delete-HD Cooler-Auburn LSD 4.56's-Mopar Cover- Modest 3" Lift-SRT Hood-RF Tactical Grille-Blk Lights-Cab Lights-OEM Hella Fogs- PWR WGN Flares-Black Bed Caps-Rails & Mopar 4" Step Tubes w/5x Amber-1OAK Steel Rims/285 Duratracs-Gator Mudflaps-Rolling Tonneau-Leather. Next:Hellwig-35's.
03MopaRamman is offline   Reply With Quote
Old 01-20-2011, 10:45 AM   #7 (permalink)
Ram Year: 2009/2003
Engine: 5.7/4.7
Default
Does this work on a 03 4.7
__________________
03 dodge 2wd bagged Daily Driver 20's
09 ram crew
1952 pk waiting to be started
http://www.rpmgraphicsandcustoms.com/index.php
STOUTE is offline   Reply With Quote
Old 01-20-2011, 01:01 PM   #8 (permalink)
Ram Year: 2003
Engine: Hemi-5.7
Default
TMR (Torque Management Request) and Line Booster are two different things. Line booster basically comes in two styles, Transgo and Sonnex, Transgo uses a 2.2k resistor parallel with the pressure sensor which is a rheostat and the Sonnex which uses a 15 ohm resistor inline or series with the sensor output. Both do the same thing in as that they alter the Line Pressure signal to the TCM.
The TMR mod on the other hand simply removes the torque management request signal to the TCM which is one of the determining inputs that adjust the internal shift (pressure) schedule and shift points. The TCM on newer model trucks is internal to the PCM. Our TCM is seperate from the PCM and allows us to access the connecting cable.
Good luck..
__________________
Old 01-20-2011, 01:23 PM   #9 (permalink)
Default
Thanks, I understand the TMR Mod Greg and how it works, Just wanted to confirm if I'm runnin the Transgo Resistor then the Sonnex Set-Up is not required? Correct!
Edit: From your reply I take it the answer is "Not ReQ." in my case. Thanks.
__________________
Old 01-20-2011, 10:17 PM   #10 (permalink)
Ram Year: 2003
Engine: Hemi-5.7
Default
Danny,
You have brought up something I have ben thinking about. What exactly are the differences between the two methods and how they altered the signal voltage. I need to experiment a little, but there maybe some benefit in making a hybrid of the two. Of course different values would have to be used but a specific voltage clamp might be possible using a hybrid.
Also I just bought a 300 psig sensor from AeroForce to use on the AI analog input to read line pressure. But thinking about it, the sensor may not have been necessary as the LP sensor voltage is a 0-5 volts signal. Maybe the signal can be directly connected to the AI analog input and read as a reference voltage? Put the trans in Reverse and whatever number shows on the AI will represent 250 psi. Then just gage the difference seen on the Ai between 0-5 when in other gears. Thinking out loud.
__________________
Reply
Bookmarks
Tags
tmr delete, transmission mod
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
TMR Delete and Smoke Shows Hemiguy0302 Engine & Performance 28 10-13-2010 10:48 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
