06-08 Headlight Disassembly/Paint
moparman33
Cordova, TN
2004 QCSB 4X4
4.7L magnum
also i ordered dupli colors match to my patriot blue. and was wondering if it would give a good finish
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I use a self etching primer from Rustoleum. I love it......not so thin like some others I've used.
The duplicolor stuff isn't bad. Get some clear too, it'll make it pop!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
oh, and take some acetone to the bezel before you paint, it'll knock out that chrome.
moparman33
Cordova, TN
2004 QCSB 4X4
4.7L magnum
i really appreciate it jeremy. i plan on workin on this tomorrow. thanks alot for the help. i plan on doin 2 light coats of primer, 3 light coats of color, and probably 2 very light coats of clear to seal it
moparman33
Cordova, TN
2004 QCSB 4X4
4.7L magnum
i know its gonna take me a while, but i also know that with the more prep you do, the better it looks in the long run
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Here is a blue one I just did........only difference, this is OEM paint, but duplicolor clear:
SLICK! :D
And you better take pics! :D
moparman33
Cordova, TN
2004 QCSB 4X4
4.7L magnum
well i finished one(driver side). my wife had to go to work and took off with my tools in the durango so i couldnt do the passenger side today. i will get to it tomorrow. after 4 1/2 hrs, 2 coats of primer, 4 coats of base color, 2 coats of clear coat this was the finished product. let me know what y'all think
Vendor
Florissant, MO
2x 5.7L & 6.2L
looks great!
moparman33
Cordova, TN
2004 QCSB 4X4
4.7L magnum
thanks. i finally got both of them done. and im very happy with the way they turned out. thank you very much for the help and advise, jeremy and matt
moparman33
Cordova, TN
2004 QCSB 4X4
4.7L magnum
heres pics of the final product
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
very nice!!!
moparman33
Cordova, TN
2004 QCSB 4X4
4.7L magnum
thanks alot y'all. without peoples advise and guidance on here i wouldnt have known how to do it, so thank you for your help.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Thats what forums are for..........if I never hopped on any of these forums......I'd be a rich ****. :D
Firk06
Tomahawk, WI
I want to do this to my 07, but i was thinking of using that VHT niteshade stuff, to let a little of the chrome shine through. Any thoughts?
Hurley91
5.7L
VHT niteshade stuff looks awful on headlights. It ends up looking purplw.
