2006 ram 2500
- Sep 8, 2016
- 4
- 0
- 2006
- 5.7
Hello everyone I'm new to this form hopefully I'm posting this in the correct area but my issue is recently my lovely Dodge pick up truck started shuttering or in limp mode every time I come to a stop fix this issueThe truck has to be put in park shut the truck off restart the truck that I can drive off like normal till I have to come to a stop again does not do it all the time but random some days will do it non stop then other days won't do it at all sounds like wire issue ? Actions I have done taken dealer pulled code p0871 I have replaced every sensor on the outside of this transmission speed sensors and oil pressure sensor pull the transmission pan change fluid and filters still doing it so I want to head pull the valve body out put a trans go shift kit in it and I also want to head and put a new solenoid pack in and when I put it all back together and all lined up and Holy hell I thought I broke my truck I could not get the ******* thing out of first gear until the air worked itself out and I added more fluid now it seems to be a little better but ever since I pulled the valve body it seems to act up more then normal I know I put the trans go shift kit in right pretty straight forward but I had tipm issues I lost low beams so I called the stealer ship they said hey we can reflash the computer and tcm for 80 bucks seems to be the issue so that's the next step unless some one can straight up tell me my trans is dead which I'd be hard-pressed to believe that 133k miles if anything transmission is gone at that point I'll be pretty disappointed with Chrysler and let me go over some more symptoms it doesn't matter when it's put in the Limp mode I can shift it in 1st gear still does it 2nd gear same truck has to be in park and off for a couple seconds then restart and then I can drive off but sometimes it will do it right after again or I won't do it again and I can drive it all the way to work without any issues the truck comes in and out of it year is 2006 Dodge Ram 2500 hemi 545rfe trans known issue with tipm thank you for all your help sorry about the long run on sentence
