Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Tech Info > 3rd Gen DIY
Sponsored Ads
Register to remove these ads.
3rd Gen DIY
Blend door removal write up?
This is a discussion on Blend door removal write up? within the 3rd Gen DIY forums, part of the Tech Info category!
Register to remove these ads. It's free! Does anyone have a write up with pictures of how to get to ...
Reply
Old 01-16-2012, 09:29 AM   #1 (permalink)
02blkram47's Avatar
Ram Year: 2002 quad cab
Engine: 4.7
Default Blend door removal write up?
Does anyone have a write up with pictures of how to get to the blend door and open it up permanately? Coldest morning of the year today and we hit -13 deg. had the truck runnning for a total of about 40 minutes between 15 min warmup this morning and then driving to work, the truck came up to temp and I was only getting mild warm temp coming from my vents. I call up the dealer and he tells me just labor will run $710. needless to say I'm thinking I can just open the door myself and deal with that. Not sure where to look or what to grab. Any help would be appreciated.
Thanks
02blkram47 is offline   Reply With Quote
Old 01-16-2012, 05:19 PM   #2 (permalink)
bigbadram1500's Avatar
3rd Gen / Site Mod
Ram Year: 2008
Engine: Hemi 5.7
Send a message via Yahoo to bigbadram1500
Default
Bumperoo for others to chime in. Anyone got one of these writeups?
__________________
RamForum.com Moderator
2008 Ram 1500 QC SB 4x4 Hemi in Sunburst Orange
SC3815, BFI, Power Wire, 2.5" Ready Lift Leveling Kit, 34" Nitto TG's, 8k Bi-Xenon Direct Fit Projectors, 6k Fogs, LED Tails, 6k Hellas behind the grill, BakFlip G2, BedRug, Wheel Well Liners, Debadged, Flowmaster 40 Exhaust, Kicker 12" CVR in Custom Console, Kicker 400.1 amp, OEM Tow Mirrors
bigbadram1500 is offline   Reply With Quote
Old 01-16-2012, 05:42 PM   #3 (permalink)
The Assassin's Avatar
Ram Year: 2006
Engine: 4.7
Send a message via Skype™ to The Assassin
Default
Eeek I haven't seen any one how to remove it. I had found a nice video on YouTube when I replaced mine.
Sent from my DROID X2 using Tapatalk
__________________
2011 SEMA Feature Vehicle, Truckin' Magazine
Custom painted Ram Club Member #1
Shaved Ram Club Member #1
Ram Forum After Dark Member #1
Supporting Member Club Member #1
The Assassin is online now   Reply With Quote
Old 01-16-2012, 06:01 PM   #4 (permalink)
02blkram47's Avatar
Engine: 4.7
Default
I love youtube for that kind of stuff. I'll check it out. thanks
edit: so I checked out a couple videos on youtube and now I'm more confused than before. I was under the impression that some people instead of fixing this blend door they would reach up under the dash and just pull the door out leaving it open all the time. My confusion is this: when I see them take the dash panel off on the passenger side the only door over there is being called the Recirculater door and not the blend door which seems to be closer to the center of the dash and has a motor attached to it. If I were having an issue with not getting really hot air would this be a recirc door issue or a blend door issue? Also If I take this door off completely do I think lose the ability to have cold air in the summer?
Old 01-16-2012, 06:17 PM   #5 (permalink)
Ramunit's Avatar
Ram Year: 2005
Engine: Hemi 5.7
Send a message via MSN to Ramunit
Default
http://www.heatertreater.net/dodge-ram-02-08
__________________
2005 QC HEMI * Bright Silver * AEM Brute Force Intake * Powerwire * Jetstream Scoop * Stant 14168 180* t-stat * Superchip Flashpaq 3865 with Trans Tune * BBK Ceramic Shorty Headers * Magnaflow Y Pipe * Magnaflow Catback * Motive 4.56 Gears LSD * Bilsteins * Chrome SRT 20's * Hankook Ventus ST RH06 275/55/20 * Alpine Audio
Ramunit is offline   Reply With Quote
Old 01-16-2012, 07:38 PM   #6 (permalink)
mikehutch's Avatar
Ram Year: 2008
Engine: 4,7
Default
The recirc door and the blend door are different.
The recirc door is used to pull cabin air in and recirculate it. So in extreme hot/cold you pull in the already conditioned air from the cab and run it through the HVAC again. When this is not in recirc you pull air from the cowl, condition it and it leaves the cab through the exhausters.
The blend door blends hot and cold air for the correct outlet temperature. So if this is stuck somewhere you may not get full hot or full cold.
Both doors play a part in how hot/cold your HVAC gets.
Your HVAC unit runs the air through the evaporator and then through the heater core. This is done as a de-humidification process when in defrost. This is why you will have the AC compressor running when in defrost. Don't want to throw moist air from the outside onto your windshield as you could end up with fog on the inside.
Max heat would be achieved in a mode other than defrost, blend door full heat and recirc door in recirc. This is of course assuming your heater core is functioning and not plugged and the engine is reaching operating temperature.
__________________
2008 Dodge Ram Quad 4.7
Mods: K&N Cold Air Intake, Debagded, Husky Liners floormats, McGaughy 2/4.5 lowering kit, Dynomax UltraFlow SS muffler, dual exhaust rear exit, painted calipers, Front seat heaters, 110 VAC inverter, smoked 3rd brake light, superchips tuner
mikehutch is offline   Reply With Quote
Old 01-16-2012, 09:22 PM   #7 (permalink)
02blkram47's Avatar
Engine: 4.7
Default
Well after driving the truck home from work I put the dial on all upper vents, no defrost or foot vents and although it took a bit the truck did have decent heat. Perhaps this mornings issue was a combination of -20 degrees and me having the dial on defrost that made it take so longtime heat up. It seems to me I'm able to move the air from vent to vent so those doors are working and I do get heat so I'm assuming the heater core is working. When the blend door breaks is all at once or would it start to fail over time?
Old 01-17-2012, 07:52 AM   #8 (permalink)
mikehutch's Avatar
Ram Year: 2008
Engine: 4,7
Default
Moving the air from defrost to vent to floor is the mode door. So you could still have a blend door issue.
I have some photos of a 2006 unit which is made by Denso here at work. Ill see if I can post some when I get home tonight.
Sent from my Droid using Tapatalk
__________________
Old 01-17-2012, 09:48 PM   #9 (permalink)
mikehutch's Avatar
Ram Year: 2008
Engine: 4,7
Default
Ok here's some pics:
This the the bottom half of the blend door system. The heater core is sandwiched between this and the top half below.
Top half of the blend door system.
Ok so this is a pretty complex blend door system. You would typically do the blend with half as many doors, well at least we would. The photos above show a dual zone system or one which the passenger and driver get to pick different settings...so the case is divided down the middle. Their are four blend doors for the dual zone. If you have a single zone then the doors are interlocked and only have the one rear actuator.
In this system it looks as if when you are in cold the doors close down and seal off the heater core. The air then goes above and below the heater core. When you call for heat the top door move up into the air stream and forces air down through the heater core. The bottom doors open at the same time(via the linkage) and allows the air to leave the bottom. If in partial heat some air will still bypass the heater core around the top and bottom. In full heat all the top air will flow down though the heater core and out the bottom.
From the heatertreater link above if you go to the detailed descriptions for the Ram it gaves a pretty good description of the doors and some basic troubleshooting...no need to retype.
__________________
Old 02-13-2012, 11:54 PM   #10 (permalink)
Hemitom's Avatar
Ram Year: 2004
Engine: Hemi 5.7
Default
What normally fails is the Blend door. mine is removed. it has been fro about 2 years. i went and bought the updated replacement part for it. the replacement has the whole top part of it. from what i can tell its just pulling the dash out on the passenger side and unscrewing the 4(i think) screws and removing the whole assembly. then putting the new one back.
http://i220.photobucket.com/albums/d...20Ram/Back.jpg
Hemitom is offline   Reply With Quote
Reply
Bookmarks
Tags
blend door diy, blend door removal diy, how to open blend door, opening blend door diy, opening blend door how to
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Scratch removal swamp_life hemi 05 Thompson Racing 6 11-07-2011 08:00 AM
Scratch removal. swamp_life hemi 05 Exterior 7 10-27-2011 09:55 AM
Console Removal ktm1217 2nd Gen DIY 4 10-07-2011 05:53 PM
Door Panel Removal to Install Tow Mirrors FloridaRam Interior 15 09-12-2011 03:13 PM
blend door problems reefguy89 General Discussions 9 06-20-2011 01:32 AM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
