Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > 3rd Gen DIY
3rd Gen DIY
Caliper Rebuild Tips & Brake Info
This is a discussion on Caliper Rebuild Tips & Brake Info within the 3rd Gen DIY forums, part of the 3rd Gen : 2002 - 2008 category!
Brakes are quite easy to work on however a lot of people skip this. A lot of money can be ...
Like Tree3Likes
  • 2 Post By sullivan
  • 1 Post By conway
Reply
Old 08-26-2011, 03:42 PM   #1 (permalink)
sullivan's Avatar
Ram Year: 2016
Engine: 5.7 Hemi
Default Caliper Rebuild Tips & Brake Info
Brakes are quite easy to work on however a lot of people skip this. A lot of money can be saved!
I can't give a full how to, but these are some tips that will help and clear up some things.
I suggest purchasing a manual for your truck if you haven't already. You can do so at your local auto parts store. This will give you step by step instructions.
Pads:
Changing the pads is very simple to do. For less then $100 you can get new pads all the way around, just visit your local auto store.
When replacing your pads I suggest buying new hardware kits for the front and rear, these consist of metal clips that hold the pads in place and new boots for the pins.
I recommend using:
CRC/4 oz. (118.294 ml.) high temperature disc brake quiet (05016) | Brake Lube | AutoZone.com
This is applied on the ends where you install the clips and prevents unwanted noise. I have had great success with with product and have had zero noise while braking.
The caliper hardware kits also include the slide boots which the caliper slides on. I recommend using this product for the caliper slide pins and boots:
CRC/8 oz. (226.796 g.) brake and caliper synthetic grease (05359) | Brake Lube | AutoZone.com
Rotors:
You have a couple of options here. If they need to be machined your local oReillys will provide this service for very cheap.
You can purchase new ones for appx. $25 a peice. Again you are saving lots of money doing an entire brake job yourself.
Calipers:
Calipers have many components that cause typical brake issues. Typically the most common are rotors that have been heavily used and overheat causing damage to the caliper.
This includes damaging boots, pistons, burning brake fluid, and these all contribute to air getting in the lines also which you don't want.
Calipers cost anywhere from $120-$160, they are fully rebuilt and ready to go. But you can rebuild your own for a mere fraction.
3rdstrike Performance on here sells the rebuild kits, as well Rockauto. I got all mine from rockauto for about $12 each shipped.
Below I will show a few photos of me rebuilding a caliper, there isn't much to it.
First things first, you need to make sure to buy plenty of DOT 3 Brake Fluid. I purchased 3 quarts of Prestone Synthetic DOT 3 Brake Fluid. Reasons being that its synthetic and you will have plenty of fluid to flush your lines and finish the job with some left over.
Below is a caliper I painted, with the two pistons, rebuild kit, 1 quart of dot3, cpress, bleeder bolt and brake line bolt.
The rebuild kits are very simple as they are only rubber boots, you have to install it a special way on the front calipers so pay attention in the next few photos.
The boots for the front calipers get sandwiched in a way by the pistons and the caliper. The boots have a bottom lip that goes inside of the caliper.
In order to do this you have to install the boots towards the bottom of the piston and then pop that lip into the caliper. From there you try to start pressing the piston into the caliper.
The pistons need to be pressed straight in, and not at an angle of any sort!
I found the best way to press the piston in with normal tools is with the cpress and a junk socket.
You inert the socket into the piston, and it goes straight in every time. Please use caution when first attempting. Press them in slowly.
Stripped and painted all of my hardware:
Installed, from here you bleed your lines of air. I will include a video below of how I learned.
This is a great video to learn how to bleed air from your brakes.
http://www.youtube.com/watch?v=LgxMfQUMdJY
AceBlackRam and usaf2006 like this.
Sponsored Ad
Register to remove this ad.
__________________
5.7 Sport -3.92 -Cooper Zeon LTZ -Tow Mirrors -HellWig Anti-Sway Bar -Bilstein HD Shocks -Magnaflow 22" -Superchips -0AWG Big 3 Upgrade-Custom Cold Air Intake -Black Billet Lower Grill -Spray In Bed Liner -Debadged -LED Tails -LED License Plate Lights -HALO Headlights -5000 HID Headlights and Fogs -Katzkin Leather Seats-LED Interior -Audio -Pioneer AVH4200 -Kicker DS650.2 -Kicker DS5250 -Kicker DS350 -2x Kicker CompVR 12" -Kicker ZX750.1 -Kicker ZX350.4
sullivan is offline   Reply With Quote
Old 11-28-2015, 12:14 AM   #2 (permalink)
Ram Year: 2006
Engine: 5.9 cummins
Default
Do you happen to still have these pictures because they arent working now
Thank you
indy05daytona likes this.
conway is offline   Reply With Quote
Old 11-30-2015, 09:01 PM   #3 (permalink)
usaf2006's Avatar
Ram Year: 2006
Engine: Hemi 5.7
Default
Same here. Have to rebuild my passenger side because I think a piston is sticking causing it to pull to the right. Truck is in perfect alignment, but still pulls. Wouldn't hurt to rebuild both of them anyways
__________________
2006 1500 RCSB 5.7, 4wd, Paid Off Build Thread
Cosmetic
Debadged Tailgate, New Carpet
Performance
Airaid MIT, SC 87 tune, LT285/70/17 Cooper ATPs
usaf2006 is offline   Reply With Quote
Old 11-10-2016, 06:05 PM   #4 (permalink)
Ram Year: 2012
Engine: Hemi 5.7
Default
Sullivan, you able to redo pics?
beep119 is offline   Reply With Quote
Reply
Bookmarks
Tags
brakes, caliper rebuild, rebuilding calipers
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jacobs Brake Exhaust Brake lilfroger 5.9 Common Rail 8 05-08-2012 12:46 PM
Painted Caliper's and added a hood decal (S.M.R) 101 Exterior 16 07-08-2011 01:38 PM
Rebuild front sway bar or get new hardware? sullivan General Discussions 15 03-07-2011 10:08 PM
need a diy, or tips badfish888 General Discussions 4 10-03-2010 06:08 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
